Antonie Steyn Posted on Aug 21, 2018
Panasoni home theater model SA-HX105 show code 9190 on display
5 Related Answers
Anonymous
  • 1512 Answers
  • Posted on Jun 19, 2008
SOURCE: need universal code for panasonic
Hi feeder
What make and model remote do you have??
regards
robotek
Anonymous
  • 624 Answers
  • Posted on Jun 27, 2008
SOURCE: PANASONIC HOMETHEATER SYSTEM TO PLASMA TV
Some where on the back, bottom or sides of your plasma tv you will find input jacks for the audio and video. You must know what type of inputs you want to use.
Most have have 4 types
HDMI (audio and video signal combined)
Component (red, blue, green RCA jacks for video only)
Composite (yellow RCA jack for video only)
S-video ( larger round black jack with video only)
The Panasonic should have all of those also. I am certain it has HDMI and Component.
Connect the HDMI cable into the output HDMI jack from the Panasonic into the HDMI input jack on the TV.
Then using your remote for the TV make sure you select the HDMI input for viewing.
If you use any of the other video outputs on the Panasonic just connect it to the same type of input jack on the TV. Once again check the owners manual for more detailed instruction if you need them.
You must always be sure to have the proper input selected on the TV to be able to view it.
You can also respond back with more questions if you have any.
I am happy to help.
Dave
appman67
appman67
  • 33 Answers
  • Posted on Sep 21, 2008
SOURCE: panasonic home theater sa-ht920
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Scott Whitehill
  • 8 Answers
  • Posted on Oct 02, 2009
SOURCE: panasonic sa-ht95 home theatre Display shows
Replace traverse assembly.
Anonymous
  • 417 Answers
  • Posted on Apr 09, 2010
SOURCE: I have a Panasonic SA-HT650 Home Theater system
A power source problem. Means there is voltage measured at the output/speaker cable connections. Indicates a failure of the amp., or faulty power supply to it.
Just re-check all of your connections, especially speakers. And that the power ac power source from the wall is wired correctly and has proper voltage and grounding.
Panasonic home theather does not read DVD and display a U703 code
Panasonic display motor Home Theater Systems Questions ...
www.fixya.com > Forum > Tags > display motor > Home Theater Systems
Panasonic home theater systems display motor related questions and answers. Ask your ... ...getting a DVD H02 code it wont play cd's or dvd it will display the code and say stop. Is this fixable or should ... ...display a U703 code. Does I need to ...
Panasonic euromax new codes Home Theater Systems ...
www.fixya.com > ... > euromax new codes > Home Theater Systems
My Panasonic home theather does not read DVD and display a U703 code. Does I need to bring the equipment to a repair center or is better to get a new one?
Panasonic Home Theater System System Dvd u703 ... - Fixya
Hi I have a panasonic theatre surround system model number SA-HT900 but I need a remote for the unit but can't find one anywhere . There is another model a panasonic SC-HT900 will the remote for this...
The remote for the SC-HT900 will work with the SA-HT900. The SA-HT900 refers to the model number of the amplifier of the home theater system but the model number for the whole home theater system including the speakers is SC-HT900.
3helpful
2answers
F61
That code means the audio amplifier IC´s are dameged and need to be replaced
SA DT310 showing F61 and closing down
the F-61 code means your audio outputs are bad you must have it repaired
19helpful
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
6helpful
8answers
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Top home Audio Players & Recorders Experts
NOEL
NOEL
 Grubhead
Grubhead
Are you a home Audio Player and Recorder Expert? Answer questions, earn points and help others
