Question about Firearms
The last bullet in the tube of my model 60 marlin won't slide in to load. all other bullets other than the last one load and fire. the last bullet can be hand loaded and will fire
Posted by James Akenhead on
  • Steve Cox
    Steve Cox Jan 04, 2019
    Clean the magazine tube. There is probably buildup of bullet lube. Try to use ammo that has less greasy/waxy lube.
Jim
    New Friend:
  • 28 Answers
Could need a new spring in the magazine tube.
Ebay has complete inner magazine tubes.
search for Marlin Model 60 .22 Inner Magazine Tube
Posted on Sep 30, 2018
3 Related Answers
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: bullets get gamed and lever locks up in open
have a look on the internet there are blow up photos of the marlin rifle there realy very easy to strip, but putting them back right,,,
well your lad did not! *** him!! wip the screw out the side for the under leaver half open the bolt and pull the under leaver down and out the gun, then pull the bolt out the rear end,,you may see what he has *ucked up in there,,,the side loading door is held on be a small screw if you drop the side door into the gun you will need to strip out the loading leaver as well to put it right,,,so dont do that!,,, let the side door screw off just a little and put the door in the right place then nip up the screw,, dont strip it!!! then slide the dolt half way into the rifle and push the loading under leaver back into the bolt,, put the under leaver screw back in and close the bolt with the leaver,,,if its not closing its in wrong again,,,rember you need to engage the leaver in the bolt before you can close the bolt,, if its not picking up the rounds its the lifting arm,,,thats a man size job look on the net for the blow up photos,,,but you may well need some expert help then,,,im not there but if i was i could strip it in my sleep? but go to googel,, and type in "marlin rifles"
Posted on Nov 18, 2009
Testimonial: "Thank you for your time.I tore it down,,found the lifting arm at the end near barrel bent open more then it should,locking the lifting movement,TY Don"
Anonymous
SOURCE: tyco RC NSECT - won't fire the bullets
We have same problem too!
Posted on Dec 12, 2009
ray gallant
  • 69293 Answers
SOURCE: loading data for leverevolution bullets in a Winchester 94 rifle?
Here are some basic .30-30 specifications of interest to handloaders: bullet diameter .307-.308", maximum COL 2.455", maximum case length 2.039", MAP 38,000 cup.
Medium burning rate rifle powders work best in the .30-30 with bullets in the popular 150-170 grain weight range. Examples of popular powders include IMR 3031, IMR 4895, H335, H4895, RL-15, and W748. For decades I have used IMR 3031 behind the 150 grain Speer or 150 grain Sierra Flat Point bullets and CCI or Winchester primers with excellent results.
The Hodgdon Data Manual No. 26 shows that 31.0 grains of IMR 3031 powder will drive a 150 grain bullet to a MV of 2184 fps, and 33.0 grains of IMR 3031 will drive a 150 grain bullet to a MV of 2364 fps.
The same source shows that 30.0 grains of H4895 powder will give a 170 grain bullet a MV of 1919 fps, and 32.0 grains of H4895 will give the 170 bullet a MV of 2212 fps.
An unusual load with very low recoil that is excellent for plinking and small game or varmint hunting with a .30-30 rifle is a 100 grain bullet in front of 15.0 grains of SR 4759 powder for a MV of 1834 fps, or 18.0 grains of SR 4759 for a MV of 2034 fps. These loads give excellent accuracy in my Winchester Model 94.
Posted on Mar 26, 2015
Testimonial: "Thanks for the info, but I have that in my reloading books. I'm looking for data on 'leverevolution' .30 cal 160 gr bullets for my model 94. My Lyman 49th edition isn't new enough."
Hornady 25 cal 117 gr r n 25-06 loads
Oct 07, 2018 | Firearms
Can u please ecplsin why when u put a bullet in the breavh with your fingers the bolt wont close but when u put it in the magazine it goes in and locks done fine is thst a saftey system
I think you are asking for an EXPLANATION of why, when you put a bullet in a CHAMBER with your fingers the bolt won't close but when you put the bullet in the magazine, it goes in the chamber and the bolt locks DOWN fine. Is THAT a safety system?
ANSWER:
No, it is not a safety system. I am assuming that you are speaking of a standard BOLT ACTION rifle in a centerfire caliber configuration. The extractor, located near the bolt face is why it won't close. When you put the bullet into the chamber and then try to shut the bolt, the extractor has to jump over the rim of the shell casing. When you place the bullet in the magazine and then shut the bolt, the bolt face pushes the bullet up out of the magazine allowing the rim of the case to slide between the bolt face and the extractor claw and feed into the chamber. After firing or if you simply just want to remove the bullet from the chamber, pulling the bolt rearward, the extractor claw hangs onto the rim until the case hits an extractor bar causing the shell to fly out of the rifle.
A good question.
I would suggest a firearms training session. Check with the NRA or a local gun club for help.
Sep 29, 2018 | Firearms
Load data for 8x57mm Mauser with 170gr hornady sst bullet
Go to http://www.hodgdonreloading.com/
Select 8x57 mauser as the cartridge, then select 170 as bullet weight. Select the brand of powder and read the results.
Aug 01, 2018 | Firearms
Loading .257 Roberts using ww super +p primed cases with IMR 4895. Minimumum and max load data please. Looking at using 39.5 grains.
Can't say without knowing the weight of the bullet.
You can see data for many calibers listed at the Hodgdon web site.
Jul 13, 2018 | Firearms
Need to know if a rifle I want to buy is legal, Marlin Rifle 22 L R Model 60 LETTER V MADE 1961[AUGUST]1962
Legal in what way? If is stolen only the police would have the serial number flagged. If is is .22 long rifle it is a restricted firearm, so depends on the laws wherever you live. In most countries it needs to be registered.The limit for antique weapons is 1896, and in such cases, the ammunition needs to be obsolete, or the weapon is a smooth bore musket. None of that applies to this weapon.
Model 60 ' Marlin Firearms
https://www.marlinfirearms.com/rimfire/model-60After 54 years and more than 11 million rifles sold, the Model 60 is one of the world's most popular 22 rimfires - and an American classic in every way. ... Enhancing its appeal, the tubular magazine holds up to 14 long-rifle rounds, while the cross-bolt safety and the manual bolt include our automatic "last shot" bolt hold-open ...‎Model 60SB · ‎View · ‎Model 60SS · ‎Model 60C
Dating your Marlin
marlin rifle 22 model 60 serial numbers Google Search
May 01, 2018 | Firearms
Did a school teacher fire a gun and injure 3 students in a classroom
Yes, according to press reports. But bullet shrapnel hit one, and ceiling debris hit two other students.
https://www.nytimes.com/2018/03/14/us/teacher-gun-accidental-discharge.html
Mar 15, 2018 | Firearms
What years was the marlin model 36 lever action .22 made
The Model 36 was introduced in 1936 by Marlin Firearms as an improved version of the Model 1893. Around the time of the First World War, Marlin dropped the "18" and started calling the Model 1893, the Model 93. But no significant change in the gun's design took place. In the period between the wars, metalurgy was changing, as were manufacturing techniques. So Marlin upgraded the Model 93 and re-designated it the Model 1936. This moniker lasted only one year, and in 1937 it became the Model 36.
Model 36s were made until the Second World War. In 1948, the Model 36 was redesigned and modernized again and was given a round bolt to replace the square . The model number was again changed to Model 336. Lots of versions and lots of small changes have been made since, but variations of the Model 336 are still in production.
Pete
Apr 06, 2017 | Firearms
Firearms Logo
214 people viewed this question
Top Firearms Experts
jws1013
Kardoc
Joseph Coppeto
Joseph Coppeto
Are you a Firearm Expert? Answer questions, earn points and help others
