Question about Maytag Refrigerators
I have a Maytag refrigerator. The temperature light on the freezer is blinking with an alarm at 18 degrees. The refrigerator is ok at 38 degrees. I removed the ice buildup. I hear the compressor running. What could this be
Posted by Rich Donatelli on
5 Related Answers
Anonymous
  • 18 Answers
SOURCE: refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Posted on Nov 15, 2008
Mark
  • 13 Answers
SOURCE: GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
Posted on Jan 04, 2009
Anonymous
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
Anonymous
SOURCE: Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
Posted on Jul 29, 2009
Anonymous
SOURCE: freezer won't freeze, but refrigerator section
one problem i had was the condensor fan had stopped working because it was clogged up with ice buildup, check and make sure the fan is not iced up, once a year i have to unclog ice from the condensor fan which located behing the white panel, which you unscrew and you can get a visual on this fan. my freezer would stop working but the fridge part was fine. something as small as that was causing this problem for me.
Posted on Apr 25, 2010
The alarm light is flashing what do I do to stop it.
Hello Mrs. Mavis;
My name is Peter. I am a retired field service refrigeration.
The alarm light is a good thing. It is telling you that something is wrong. Generally, the alarm goes off when there is a temperature problem in either the freezer section or your fresh food section.
You only have one cooling source and that is in your freezer. Your freezer will satisfy its own temperature before it feeds your fresh food section.
Ok, Your freezer temperature should be between -2 & + 2 degrees F. Your fresh food section should be between 35 & 40 degrees. F. Adjust you temperature settings accordingly. Wait for a few hours to see if the alarm goes off.
Another problem with maintaining temperature control; people tend to over pack their freezer or fresh food section. Check to make sure your food product does not over extend the shelves. Also check the racks on the doors. Check to see if food product does not over hang the racks.
You also need to maintain your refrigerator. You have a cooling coil like the radiator in your car, it gets rid of heat. You must keep this clean. A dirty condenser coil can effect your temperature by as much as 40 degrees F. This coil is located either under in the front of your refrigerator or a canister looking item in the back of your refrigerator behind the lower cover.
Look at the back of your freezer wall. Is there a lot of frost or ice?
This could be either a defrost heater or freezer fan motor.
Call me. Lets talk about this more. 443-306-1362.
Nov 04, 2014 | Refrigerators
Fridge not cold enough
The higher the number the colder the temp is supposed to be.
In order to prevent the formation of bacteria and other such organisms to affect food the way it does, the ideal temperature range of refrigerators has been mentioned here. Before we look at these settings, it is important to know the format in which temperatures are represented within a refrigerator. Commonly, you will notice a dial representing the figures 1-5 or 1-9 in the refrigerator, and a dial representing the letters A-E in the freezer. The ideal setting is usually in the middle of such figures.
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 degrees F - 38 degrees F or 1 degrees C - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrees C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Belling Refrigerators
Temperature of thermo defrost samsung
The ideal temperature in the refrigerator ranges between 34 - 38 degrees F or 1 - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrress C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower. See more at:
Mar 01, 2014 | Refrigerators
Electricity off want to reset temperature. What should frig and freezer be set?
Temperatures are preset at the factory at 38 degrees or 3 C in the refrigerator compartment and 0 degrees F or -18 C in the freezer compartment. Here is a link=> MFI2067AES User Manual to the user manual for your model that explains how to set the temperature, I am here should you have questions Thanks Sea Breeze
May 29, 2013 | Maytag MFI2067AES Stainless Steel Bottom...
What's the optimal freezer and refridgerator temperature?
The ideal freezer temperature is 0 Fahrenheit (-18 Celsius) for storing food. And -10 Fahrenheit (-23 Celsius) is recommended when freezing food.
The preferred temperature is somewhere between 35 and 38 degrees F (1.7 to 3.3 degrees C).
Mar 01, 2011 | Refrigerators
What is the average temperature for a Maytag MSD2272VEW?
The factory settings for the side by sides are -18 degrees c for the freezer and 5 degrees c for the fridge
Jan 27, 2011 | Maytag MSD2272VEW (218 cu ft) Side by Side...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Freezer due to brown out then power restored now low temp alarm
The light should reset itself when the freezer gets to less then 18 degrees. If it is still above 18 degrees it will stay on. Now if it is cooler then 18 degrees then unplug the unit for 1 minute and plug it back in once you are sure that it is below 18 degrees. But do not rule out the thermostat. It could have blown out when the brownout happened. To test it jump the wires together and see if the freezer comes on and goes off
Feb 14, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerators Logo
143 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
