Question about Yard Machines Garden
Pinion on a yard machine mower 638rl
Does not steer can't move wheels left or right
Posted by Frances P on
5 Related Answers
USfalcon
anwar alkhaldi
  • 197 Answers
SOURCE: locked steering wheel
try to spray inside the key lock cylinder (the place where u put ur key ) by PB puster or WD40 then turn the steering wheel lift and right with try to turn the key to position on
i hope this will help
Posted on Mar 17, 2009
freetek
Steve Allison
  • 5569 Answers
SOURCE: 2002 honda odyssey,the right front wheel makes a
This sounds like a wheel bearing close to complete disintegration. I advise you get the front end free of the ground so you can check for it by grasping the wheel and attempting to rock it from side to side. It isn't hard to imagine that if it is indeed that worn, that the wheel could separate possibly taking the axle and CV joint with it. Don't take any chances - it's urgent that you find the problem quickly.
Posted on Jun 05, 2009
Anonymous
  • 4 Answers
SOURCE: No Power Steering. Replaced rack & Pinion,
U HAVE AIR LOCK LOOSEN HOSE START CAR TURN WHEEL LEFT 2RIGHT TIGHENBACK
Posted on Aug 16, 2009
Anonymous
  • 867 Answers
SOURCE: steering wheel lock
make sure you turn the ignition key at least a bit first
Posted on Nov 25, 2009
Anonymous
  • 97 Answers
SOURCE: when turning steering wheel to left very hard to turn
Sounds like the begining of a bad rack n pinion. We can eliminate the pump because the car turns to the right fine. There is no loss of fluid? The only thing left is the rack. It is a fairly commin issue. Use to call it morning sickness, The cars would be hard to turn in the morning or when first started but after running and warming up for a while they would start to work properly.
Posted on Jan 20, 2010
My steering wheel on Merc C280 1995 model. While driving I can move the steering wheel slightly left to right, but the car remains straight. Then the car will veere right and then left slightly without me...
Check steering wheel nut is tight, sometimes it may run loose. If it is tighten to specs and is still happening, splines may be worn on steering wheel.
Mar 04, 2015 | Cars & Trucks
Clunking noise when steering wheel is moved back and forth.
Sounds like you have ball joint or steering linkage problems..have some one set on the seat and make hard turns right and left while you watch for excessive movement " linkage or ball joint slap " before the wheels actually turn..or jack the front end up one side at a time and with the steering wheel strapped in place"bungee chord " move each wheel up and down and left to right..find the excess movement and go from there..good luck
Oct 22, 2014 | kawasaki 2008 Mule 610 4x4
Ignition key won't turn
Try turning the key while jerking the wheel left and right and depressing the brake pedal. If that won't work try another key.
Oct 17, 2017 | 2002 GMC Sierra 1500
I was mowing and all of a sudden it stopped steering. The front left wheel moves when I move the steering wheel. The front right doesn't. I can move the front right without moving the steering...
Sounds like the tie rod has came loose or broke, look for a rod that connects the working wheel to the steering and then compare it to the non working side and you will be able to see what is missing
Jun 27, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Car is parked and off but unable to turn key in ignition and steering wheel is locked.
Try moving the steering wheel left and right as you turn the key - sometimes the steering lock will stick if there is pressure from the wheel. If this doesn't do it, try spraying or pouring some dry graphite into the lock cylinder ( the hole for the key) slide the key in and out of the lock quickly a few times to spread the graphite, then move the steering wheel left and right as you turn the key.
Hope this does it for you!
Nov 09, 2010 | 1997 Chrysler Concorde
Wheel pulls left to right at speed
Check tire inflation, brakes, and alignment, in that order.
Aug 25, 2010 | Ford F-250 Cars & Trucks
1996 camry le 6 cylinder. cannot get ignition key to turn to start car. gear is in park and have tried adjusting steering wheel
Hi the steering lock could be causing you the problem try turning the steering wheel hard left whilst turning the key and do the same hard right.
it may be hard to turn but you should find once you have moved it slightly it will unlock allowing you to turn the key so dont adjust the steering wheel turn it to the right as if your trying to turn to the right and if this dont let the key turn turn the wheel to the left it only needs to move slightly to allow the steering lock to free the key,
doing the above should solve you problem
give me a shout back if you have any further problems ok
Aug 15, 2010 | 1996 Toyota Camry
How do I align the steering after I replace the steering gear box so I have equal rotations on the steering wheel from left to right on a 1992 chevy astro van?
with the front of the vehicle raised in the air (with jack stands underneath), turn your steering wheel lock to lock, counting how many times the steering wheel does one complete rotation..........halve this number and rotate the steering wheel the opposite way...this will be the approximate middle of the steering rack movement
One important ppoint to note that not all items are built exactly, so you will require a wheel alignment after any change in steering or suspension components to be sure that everything is running true and correct
Aug 02, 2010 | Chevrolet Astro Cars & Trucks
Garden Logo
48 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
john h
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
