What is f03 and e02 error codes on duet dryer[not washer]?
Posted by scottie rodgers on
5 Related Answers
Anonymous
  • 27 Answers
SOURCE: Bosch Nexxt Washer Error Code E02
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
Posted on Jun 26, 2007
Anonymous
  • 16 Answers
SOURCE: wd640 hotpoint washer dryer - error code F03
This indicates that the wash thermistor is "Open Circuit" and I think it is situated on the heater assy at the back of the machine.
Check the wiring and contacts between the thermistor and the PCB. If you still get the fault it could be the Thermistor ( which means replacing the heater ) or a faulty board.
If it is under 5 years old - Call Hotpoint as you have a 5 years Parts Guarantee mind you the call out is £89.98 but thats cheap if it happens to be the board!
Posted on Mar 16, 2008
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Whirlpool duet washer F21 error code. Just bought
"F21" is a Long Drain error. The following link explains how to torubleshoot:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
What this usually means is that you have something clogged in the drain pump and it needs to be cleaned out. In the majority of the cases, this corrects the problem. However, if you JUST purchased this washer, and it is brand new (not used), I would recommend you use your manufacturer warranty (good for the 1st year in most cases) to avoid the risk of voiding it. The conditions of some warranties, prohibit the consumer from opening the appliance and attempting any repairs. Read the find print just to be sure.
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 09, 2009
Anonymous
  • 50 Answers
SOURCE: front load frigidaire washer w/ error code
The F03 code is a problem with your water system. your inlet valves may have failed.
Open up the bottom panel and you will find a tech sheet that explain the codes and gives trouble shooting techniques. here is the service manual, good luck, hope this helps......
http://frigidaireservicetips.com/pdf...icControls.pdf
Posted on Jan 06, 2010
Anonymous
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
F06, E02
I think these problems are related to water inlet, take off the hoses from the back of washer and you will find a screen in the outlets clean with old tooth brush until clear.
Feb 19, 2014 | Whirlpool WFW95HEXW Duet 5.0 cu. ft....
Error code F01 E02
For how long did you unplug the power cord? If it was under 5 minutes, unplug it for longer. Check if that clears the error code. If it doesn't, the motor control unit needs to be replaced.
Please double check your model number to get the correct part. Most of the Whirlpool washers have model numbers that start with 3 letters.
I hope this helps.
Dec 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I just plugged my Duet washing machine in and per all directions hooked up everything and rechecked and there is an error code of F03 and E02 that pops up the screen??? please help
Hello, if it new then do mess with it. Call the vendor who sold you this washing machine and have them bring out another washing machine. And take this one back for a boat anchor. GB...stewbison
Sep 06, 2011 | Washing Machines
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I have 2 error codes on my front loading Whirlpool washer...F08 and E02...What do they mean?
well I'll just say it's the kaputnick gate valve located at the whirlpool headquarters since no-one else seems to have the same explanation for a single error code
Apr 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
1,363 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
