Question about Jet Health & Beauty
Can I use a 24 volt off board charger on a 12 volt batteries I have a Jet 3 ultra
Posted by John Harris on
Jeff Bird
  • Jet Master
  • 1,346 Answers
Hi if u have 2 x 12 volt batteries connected in series :::: this bring the voltage up to 24 volts u can use it ..cheers
Can I use a 24 volt off board charger on a 12 volt - img_20180821_125938-zrzhqiylagscoee0vhdhdi2o-2-0.jpg
Posted on Aug 21, 2018
5 Related Answers
Anonymous
  • 1605 Answers
SOURCE: Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
Posted on Oct 20, 2008
peter evan
  • 103 Answers
SOURCE: charger for 12 volts 7 amp battery smf
you need to go to a **** smith store and bye a kit to do this cheers peter
Posted on Apr 12, 2009
Anonymous
  • 53 Answers
SOURCE: wiring diagram for 12/24 volt system
here is a wire diagram. follow the pictures. you can do fuses but i like inline breakers. you can get them at your local outboard dealer.e9e9f8a.jpg
Posted on Nov 05, 2009
Anonymous
  • 14 Answers
SOURCE: When I plug in my jet 3 ultra the ammeter reads 0.
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
Posted on Mar 07, 2010
Anonymous
  • 5 Answers
SOURCE: I have a 767P motorguide that is 12/24 volt. The
Yes and ...no. I'd look for one made for marine use... although any good quality switch will work...for a time. Corrosion will catch up with a :cheapie."
Try these guys... http://www.trollingmotorparts.com/default.aspx/MenuItemID/184/MenuGroup/Home.htm
Good Luck and God Bless, Luckymann77
Posted on May 14, 2010
I have a blue jet 3 ultra n i just put 2 new batterys on it and all it will do is flash a red light in the top left corner of the battery light on the joy stick and the horn works but will not move what...
Check your battery wiring on the Jet the wires from the circuit breaker need to connect the positive of the front battery to the negative of the rear battery and the other wires connected to the positive of the rear battery and negative of the front battery putting the batteries in series to generate 24+ volts. If you have a voltmeter before you check the wiring set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. If your batteries are wired correctly you should be reading 27+ volts without the charger plugged in and your batteries fully charged. If you are only reading 12 volts then the wiring is wrong and needs to be fixed. Leaving the voltmeter in the charger port plug in your charger and you should be reading 27 -30+ volts at the charger port anything less than 24 volts indicates your charger is not charging Hope this helps
May 22, 2011 | Jet 3 Ultra Power Chair
I cant get my power chair jet 3 to charge batteries are good
Hi valentin 201
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. . In the future give as much info about the scooter as possible.
1. load test the batteries even if you think they are good, check anyway. Sometimes even new batteries won't hold a charge.
2. Your charger on the powerchair must have enough volts to open the charger inhibitor. That is, the charger won't even start up if your batteries are low. Both batteries need to have at least 20-22 vdc.
3. Some chargers have a 3amp fuse check that and repace if needed.
4. With a multi meter set on dc200 check your batteries. Red on one battery and black on the other. Check to see what you get for voltage. If no voltage reverse the lead wire to the other posts. Once you get a reading of 20+ volts watch the meter and plug in the charger, it should increase the volts on the meter. if not the charger is bad, replace. Charger should be 24-31 volts to be a good charger.)
One of these sugestions will fix the problem
Good Luck
Tim
May 03, 2011 | Jet 3 Ultra Power Chair
Will not charge. amp meter does not move. has current all over the chair when pluged into ac
Midway if you hava power when the charger is plugged in and you aren't getting anything when unplugged I would say you have a battery problem. If you have or can get ahold of a digital voltmeter set it to 200 volts dc and plug the leads into the two outter plug holes in the charger port located under the front of the joystick. Without the charger plugged in you will read the battery voltage. It should be 24-27+ volts fully charged. Now plug in the on-board charger and you should read 27-34 volts indicating the charger is working. Hope this helps
Nov 08, 2010 | Jet 3 Ultra Power Chair
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
Batteries won't charge, bought new batteries and they won't charge either
Moore well it looks like you have a charger problem. With a digital voltmeter plug the on-board charger into the wall then take the voltmeter and plug the two leads into the two outter plug holes of the charger port under the front of the joystick set the meter to 200 volts dc. with the charger plugged in you should read 26-30 volts if you don't get that you are reading just the current battery charge 20-24 volts. If you can try to find someone locally that has an offboard charger and borrow it for a few hours. Plug the offboard charger into the charger port under the front of the joystick and let it charge the new batteries. I would try to find someone with an extra charger you could buy or contact your local provider and have them get you an off board charger to charge your chair. Hope this helps you
Sep 23, 2010 | Jet 3 Ultra Power Chair
I charge my jet 3 ultra with the cord but as soon as i remove the cord it dies what do I do? I no longer have the instruction manual
jaeger How long have you had the chair? And have you changed the batteries or had them changed within the last year? The problem could be the batteries. If the were run down or not charged for a long time then your charger cannot pick them up enough to reach a full charge or in your case no charge at all. Now if the batteries are fairly new but have run down the problem could be the charger. If you have a digital voltmeter and your Jazzy has an on-board charger -- plug in the charger then put the test leads in the charger port two outter plug holes under the front of the joystick set the meter to 200 volts dc. You should read up to 30 volts with the charger plugged in. Now unplug the charger and you will read the battery voltage it should read 24-27 volts. If when you have the charger plugged in and you don't read up to 30 volts then the charger is bad If after charging overnite and you don't read 24-27 volts the the batteries are bad If Medicare purchased your chair then you can call a service company to repair your chair and they will bill Medicare for the cost of the repair. Medicare will pay 80% of the cost. You can call Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have a tech come out and rpair your chair. Hope this helps you
Sep 08, 2010 | Jet 3 Ultra Power Chair
Flashing red light batt. fully charged
Flashing red light usually means low batteries. Check the batteries after charging all night with a volt meter through the charger port you should read 26-24 volts dc. If you get a lower reading and you are sure the charger is working correctly then you will need to replace both batteries Hope this helps
Aug 21, 2010 | Jet 3 Ultra Power Chair
I just bought new batteries for my Pride Ultra Go Go, but can't get them to start charging when I plug the charger directly into the outlet. Help please.
1.Make sure you installed them correctly.
2.Check the voltage on the batteries. If either (or both) register less than 11 volts, either return them for ones that have 12 volts, or attempt to bring them up to 12 volts with an automobile battery charger. Once brought up to 12 volts, install them, then make sure you recharge them with the supplied charger/adapter before or when the on-board indicator it shows low (red). If the battery voltage drops too low, the supplied charger simply won't even try to charge them.
Aug 06, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Battries are discharged and now charger does not operate
The batteries will discharge below the reference voltage required for the charger to "see" the batteries if left uncharged for more than a month or more. You have to carefully bring the batteries back up to about 12 volts each for the charger to see them. The easiest way is take them to a qualified battery shop that has a step charger for sealed batteries. If you attempt to use a car charger on sealed batteries, you will ruin the batteries or even blow them up as the cases are sealed and the gas from charging has no way to escape. Some people have used a standard car battery charger on low only, applying a charge to one battery for about 15 minutes, then the other for 15, etc. until the batteries are back up to 12 volts, but again, using a car charger is dangerous and could cause the battery to explode.
May 20, 2010 | Jet 3 Ultra Power Chair
Health & Beauty Logo
48 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
