Question about Midland Radio Communications
I have a Midland two-way radio that works fine. However, whenever I put the earpiece in, I can hear others but they cannot hear me when I speak...
Posted by Dennis James on
5 Related Answers
sandrew
andrew pester
  • 2961 Answers
SOURCE: Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Posted on Aug 07, 2007
wyoed1
Ed Meshechek
  • 211 Answers
SOURCE: midland cb model 13-895
Hi Frank, It sounds to me like you may have a bad dectector diode. Other possibilities are cold solder joints in the stand up boards in the IF section. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
roti101
SOURCE: Motorola RazR V3 not working while charging
i am having that same problem........my razor had a fall and when i picked it up back there was no sound also it wasnt able to charge however i opened it and i realized that the speaker moved a little so i put it back where it suppose to be........after i powered up the fone the sound was back but styll not charging..nor recongnized by the pc....
Posted on Jan 27, 2008
Anonymous
SOURCE: Plugged in headphones for call, now earpiece doesn't work
Same here. I tried many things but cannot ring it back to headset mode. I continuously see the headphone icon shown in the phone, so it seems that the phone thinks that it is still connected to earphones. Sometimes, it works fine, but mostly it does not. If I connect the phone on bluetooth earphones, it works fine.
Any help will be appreciated.
Posted on Jul 17, 2008
Paul Blessing
  • 188 Answers
SOURCE: samsung alias earpiece speaker
Possible the earpiece has gone bad. Can you test with another earpiece?
Remove battery and examine metal contact points for dirt. Can clean with a pencil eraser.
Posted on Jul 19, 2009
Whenever i make or receive calls i can not hear the other person through my phones earpiece i can only hear them if its on speaker phone how do i check if my earpiece is dead?.what to do?
It is the hardware, the earpiece, you answered the wuestion yourself.
When there is no sound thru the earpiece, try using the speake mode or a bluetooth, if both works, then it's the earpice that is damage. I have no idea what phone model you have, but it can be replace or fix.
Jan 09, 2015 | Cell Phones
My nokila 6020 works fine but if sumone phones me they can,t hear me speaking and i can,t hear them , txts work fine etc.....
Hi, that mean, phone earpiece problem or maybe LCD frame gap from board, try to fix both screw on top lcd frame, or..change earpiece speaker. :)
Jul 31, 2011 | Nokia 6020 Cellular Phone
We purchased the midland two way radio, the problem is the channel we are on we only can hear every one in our group, but can not communicate if they are on their radio. How can we get on the same...
You should ask the others what channals they are on if you cant for whatever reason then scan for a frequincy that has others on it by hitting the scan butten and hitting the channal up or channal down butten, if you can tthen talk on each channal in order and wait 10 seconds for a reply then go to another channal and try agean, im not sure if you can hear others unless they have the same brand radio's but i could be wrong, i am also not sure if the scan butten will work so after it goes through all of the channals 2 times then try the other suggestion. you also want to make sure you have good batteries in when you try.
Hope this helps
Gamer71796
Feb 14, 2011 | Midland Two Way Radio
My eirpiece does not work at all. it seems like there maybe a problem or it is a setting i dont know about. whenever making a phone call the person on the other line can hear me but i cant hear them unless...
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Sep 02, 2010 | Pantech Matrix Cell Phone
Ive been useing my cb for about four weeks and just today the little meter thing on the left hand side stopped working when i speak but works just fine when the signal is coming in. and ppl cant hear when...
Hi take over
Sounds like you may have a defective radio and may need to send it back. I had the same problem with mine but was out of warranty so i dove in and found mine to be the low voltage transmit circuit.
This sounds like it may be to new to remove the covers off of though so I would allow midland fix it. hope I helped .
Thanks Ray
Aug 23, 2010 | Midland 5001 40-Channels Base CB Radio
When I answer a call, I cannot hear my caller as they speak.
hi...
the problem is seems to be with the earpiece. the connection to the ear piece may be disconnected.so please give for service in near by sony service centre.
Jul 14, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
S it my CB antenna or something else
take a 9 foot wire to the bad radio put the the wire into the center of the ant jack a see if you can hear your buddy glass mount ant are ****.
9 foot whip is best in car/truck 4 foot fiberglass cophased are next 4 foot are next mags are ok but over time and moving around they will mess up you paint
Jul 07, 2009 | Midland 1001Z 40-Channels Base CB Radio
Midland GXT800 radio, opened, reassembled, won't charge now...Help!
hi ive got a midland 3001 and i carnt find any one to speek to ?
Jan 10, 2009 | Midland GXT850VP4 Two Way Radio
Midland cb model 13-895
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Midland 1001Z 40-Channels Base CB Radio
No sound for phone; problem with fm radio
I have seen a similar problem in other devices. Your description led to a suspicion about the earphone/mic jack. When you insert the lead, it displaces a switch that simultaneously turns the built-ins off and the external on. These can bend outwards or stick in the out position. (The "switch" I mention is usually a strip of metal you can see inside the socket.) Attempts to correct this are all at your own risk. You could try a drop of electrical cleaner and some plugging & unplugging.
Nov 18, 2006 | Microsoft Windows Mobile 2003 for Pocket...
Radio Communications Logo
104 people viewed this question
Top Midland Radio Communications Experts
eradiostore
eradiostore
Michael Thomas
Michael Thomas
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
