Question about Kwikset Locks & Locksmithing
Kwikset 888, trying to marry it to my iPhone 8 +, won’t do it auto, need 8 digit code for input but box has 10 digit bar code # .
Posted by salvador hinojos on
3 Related Answers
fixberry
  • 437 Answers
SOURCE: Can I please get the 8-10 digit unlock code for BlackBerry 8100
Enter http://blackberrymep.com and request your unlock code, the entire operation will take about 5 minutes .
Posted on Mar 19, 2010
ib_yang
Ivy Cada
  • 1098 Answers
SOURCE: i need the 8 or
Hi.
You can obtain the PUK code from your network provider. This is a code identified with your sim card or mobile number. If your sim card is a prepaid plan, you can get this from the sim package, from that card where you took out the sim. Otherwise, you can get it from your mobile network provider.
Thank you for using Fixya!
Posted on Mar 31, 2011
forever4
  • 26 Answers
SOURCE: My simcard is locked and
ya surely you can get the unlock code for your samsung mobile , just visit this site www.wickedunlock.com/samsung/rs11wp8 , in this site you can get the code for your mobile from the network lock with best instructions and easy understandable methods for unlocking mobile phones..........
Posted on Sep 22, 2011
How do I change the code on a Kwikset key pad
Here you go....
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
pb1000programbutton
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
Aug 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Just want to change 4 digit code to new one
Do this, with the door open:
Remove cover from assembly by sliding cover up and off. You will then see the program button.
A programmed code can be from four (4) to eight (8) digits long.
Up to 2 user codes can be entered.
Excess delay in the programming steps once started will cause unit to beep twice and will require you to restart from step (a).
Programming the first User Code:
a. Press the program button on the interior unit once.
b. Enter in 4 to 8 digit code onto the keypad.
c. Press the "LOCK" button to save code.
d. Extend the bolt by pressing the "LOCK" button and re-enter the code to test. The bolt should retract to the unlocked position. If it does not unlock, repeat steps (a) through (c).
Programming the second User Code:
a. Press the program button on the interior unit twice.
After programming in just one new code, the existing old code may still work. I suggest that if this is the case, that you program in two codes to make sure that the old one is over-written. You may try programming in the same new code both times if you don't want to have two codes.
Here is a link to the installation and programming instructions that I excerpted the reprogramming instructions from:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
For further assistance or warranty information: call 1-800-677-5625 USA & CANADA
or visit, www.kwikset.com
Jul 26, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
It won't link to my home security system.
The Kwikset 909-15 lock is a stand-alone device and is not designed to link to an external home security system.
Here is a link to the installation and programming instructions in PDF form--you will need Adobe Reader installed on your computer to open this file (http://get.adobe.com/reader/):
For assistance or warranty information: call 1-800-677-5625 USA & CANADA
Jun 16, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The door locks when you put in the code and unlocks when you push the lock button.
Your problem is likely that the lock is programmed for the "wrong-hand"-left door versus right door installation. Here's a link to the installation instructions; pay close attention to step 8:
Feb 26, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
How to reset code
Here's a link to the Kwikset 909-15 information page:
http://www.kwikset.com/Products/Details/Electronic-Locks/909-15-SMT.aspx
Following the link to the Installation Guide:
On Page 8 starts the Frequently Asked Questions. Please pay close attention to the possibilities listed there--I think you'll find a solution to your problem there.
Customer Support:  http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 15, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
I just installed a Smartcode Deadbolt and I follow the directions but I cant program a code and it trys to lock itself every 30 seconds. what do i do
On the back of the unit slide the cover off and push the 2nd switch (on the contorl panel of four switches) down.
To program the code, push the black button once and enter a 4 to 8 digit code, then press the middle lock button. To set a secondary code, press the black button twice, enter 4 to 8 digit code and press the lock button.
This should all be self explanitory in the instruction manual.
I have one of these on my front door and its fantastic. I carry a key but have not used it in months. Bravo Kwikset, Bravo!
Aug 14, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
I need to change my code on a kwikset model 907-l03 asap
Take the cover off on the inside.
A push the program button
B enter the desired 4-8 digit code
C push the lock button to set your code
D enter your code to insure it retracts the deadbolt
To enter a second code push the program button twice and repeat steps B thru D
Jan 24, 2009 | Kwikset 907 907-L03 Lifetime Polished...
How to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
  • Remove the inner cover plate from the lock.
  • Locate the small round program button near the left side of the circuit board (Red or Black).
  • To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
  • Remove inner cover plate located above the thumb turn on the inside of the door
  • Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
  • Ensure that the batteries are correctly oriented or unit will not function properly.
8. Changing the password code: - please follow these instructions:
  • Manually put the bolt in extended (lock) position. Press PROGRAM button once, enter new 4 - 8 digit code and then press LOCK.
  • Press PROGRAM button twice, enter the same new code and then press LOCK once.
  • Press PROGRAM button three times, enter the same new code and then press LOCK once.
    These stept will program only the new code you enter for your unit.
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
  • Take out batteries and unplug powerstrip.
  • Let is sit for 1 minute then put the batteries back in and wait another minute.
  • If it does not beep, the keypad needs to be replaced (17733-1).
  • If the unit beeps, the powerboard needs to be replaced (A17734-4,3 Powerboard 1460 brass finish; A17734-4,26D Powerboard 1460 satin chrome finish; A17734-4,5 Powerboard 1460 antique brass finish; A17734-4,11P Powerboard 1460 bronze finish).
Nov 02, 2008 | Kwikset Powerbolt/Electronic Deadbolt-...
My iphone won"t turn on
you should be able to reset it by keeping pressed the top button and the home button for more than 10 seconds when it si connected to you computer. let me know if it works!
Apr 08, 2008 | Apple iPhone Smartphone
Locks & Locksmithing Logo
343 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
