Question about Zephyr Kitchen Ranges
Zephyr Savons ZSA-E30CS will only work on first speed. No lights work Is this a switch or control board issue?
Posted by Kathy Ryan on
1 Related Answer
Anonymous
SOURCE: Zephyr Savona Range Hood only speed 3 works
had same problem (w/in a few months)
switch assembly poor design
thay sent a replacement (i put it in)
seen other complants
Posted on Jul 20, 2008
Zephyr Savona has blue blinking light. What does that mean?
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
Replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at [email protected]
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
4helpful
Need to change lightbulb of Zephyr Savona Zsa-m90s
I'm not sure if my Savona is the same one, but on mine, just remove the filter and you can see the base of the light bulb up above the fan base. You can see where the bulb screws into the fixture. Grab the ceramic portion of the bulb, and turn that part. You may want to steady the socket with your other hand because it is very flimsy.
3answers
Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
How to install the ventless Zephyr ZSA-M90AS
Here is the link that has the rough in you need pls review me. Thanks
http://www.zephyronline.com/docs/brand_essentials/products/manuals/savonaa_manual.pdf
Zephyr ZMI-M90S stopped working
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Kitchen Ranges Logo
Top Zephyr Kitchen Ranges Experts
Vish Iyer
Vish Iyer
Dale Copeland
Dale Copeland
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
