Cars & Trucks Logo
Debbie McClain Posted on Aug 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have 2011 cadillac dst, the speedometer changed from english to metrics, checked manual, says english, but still reads metrics
Larry Blais
Level 3:
  • Cadillac Master 800 Answers
  • Posted on Sep 28, 2018
Larry Blais
Cadillac Master
Level 3:
Answers
800
Questions
0
Helped
330439
Points
2735
Hi. You would select Language for English. You need to scroll and select UNITS. From there you can choose between US, Metric and Imperial.
4 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jan 18, 2009
SOURCE: change mileage and temperature from english to metric
Look to see if you have an Info Centre on your dash. If you do push the Info button until mileage comes up and click Reset it should change from english to metric. Changing the temp is done the same way. If you have an owners manual it will tell you how to do it as well. Hope this helps
Anonymous
  • 359 Answers
  • Posted on Jul 15, 2009
SOURCE: how do i get my speedometer off of metric system?
in the drivers information center is where the settings are
Terry Engel
  • 176 Answers
  • Posted on Sep 14, 2009
SOURCE: How do you change the instrument panel back to English ?
Try pressing the tripometer reset button in rapid hits, watch for your language setting to come up.
I hope this help you.
Thanks for letting FixYa.com...fix ya
Terry
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Jun 06, 2010
SOURCE: My 1991 Cadillac Seville speedometer sometime
BCM and right lower switch at the info center.
Testimonial: "Aloha from Hawaii. My wifes 91 has not reached 100K yet but every once in a while has a senior moment. The strange condition has not happened again but the information was very helpfull. Mahalo and Thank You."
2answers
2helpful
My 1990 Deville reads fuel in Liters, and temp in degrees C, how can I correct this?
If you have the digital dash the button marked E/M changes it from english to metric and back.
My odometer is showing KMs and the speedometer is showing twice the speed on my 2006 Pontiac G6
There is a setting in the driver information panel for English or Metric units. Change this to English and you will see MPH on Speedometer and Miles on Odometer.
The speed odomitor is broken
I have a 2004 CTS and thought my speedo was broke. It was reading very high and the odometer was wrong. My wife had accidently changed the reading to metric from english on the information center. Maybe your problem?
2answers
Terry
1helpful
How do i get my speedometer off of metric system?
2helpful
2answers
Speedometer is going to fast
Does your car have a english/metric switch or option in the settings of the DIC? You may have it set on metric, which will cause the speedo to read killometers instead of mph.
Change mileage and temperature from english to metric
1helpful
3answers
Speedometer
THE SPEEDOMETER OR THE ODOMETER? THE SPEEDO TELLS YOU HOW FAST YOU ARE GOING AND ODOMETER READS THE MILAGE OR KILOMETERS TRAVELED.
IF YOU MEAN THE ODOMETER THEN THE CAR IS PROBABLY FROM CANADA AND CAN NOT BE CHANGED. I'VE RUN INTO THIS BEING NEAR THE CANADIAN BORDER.
I AM NOT SHURE IF YOU CAN CHANGE OVER TO A NEW CLUSTER (INSTRUMENT PANEL) LEGALLY OR NOT. CALL YOUR LOCAL D.M.V. AND THEY CAN TELL YOU. THE MILAGE WOULD HAVE TO BE CONVERTED AND THEN THE MILAGE STORED IN THE ENGINE/TRANS. COMPUTER WOULD NOT MATCH THE ODOMETER READING. SORRY HOPE YOU CAN FIND A SOLUTION IF YOU NEED TO.
IF YOU MEAN THE SPEEDOMETER THE THERE IS A ENGLISH/METRIC BUTTON TO PUSH TO CHANGE THE DISPLAY. GOOD LUCK..
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
