Question about Hitachi Tools & Hardware - Others
Porter cable PCC790 cordless nail gun fires but no nail comes out. Magazine won't open.
Was using Bostitch 18 gauge nails and worked fine. Ran out and salesman recommended Hitachi nails. The first nail bent and jammed the nailer. I cleared the jam. Now it fires but no nail comes out. The magazine will not open.
Posted by Pam H on
ray gallant
    Top Expert:
  • Hitachi Master
  • 67,977 Answers
NAILS ARE TO BIG
Posted on Aug 20, 2018
  • Pam H
    Pam H Aug 20, 2018
    I used exactly the same size and gauge nails. Compared the packages before I installed them to be sure. What I want to know is how to get the magazine open.
4 Related Answers
rowdy45176
David Ford
  • 2176 Answers
SOURCE: Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Posted on Feb 21, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
Alan Barben
  • 99 Answers
SOURCE: how do i clear a nail jammed in the gun?
I may need more information but you ,should be able to take it apart like any other nail gun.
Posted on Aug 03, 2009
yoopertech
  • 131 Answers
SOURCE: On the Hitachi NR83A2 nailer. Where does the end
It goes thru the same hole as the magazine bolt on the nose. Sounds like yours is broken.
Posted on Oct 10, 2009
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
How to load bostitch sb1664fn nail gun
Push on the button on the rear of the tool to open the magazine. Pull the magazine back. Load nails in the stationary part of the magazine with the heads of the nails at the top of the magazine. Push the sliding section of the magazine back into place making sure it latches.
Jul 04, 2011 | Stanley Bostitch FN16250K - 2 16 - Gauge...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
How do I load the 2 1/2 inches nails to my 16 ga porter cable finish nailer? How do I put the oil and what part of the gun?
You need to open the nail magazine and you just load one strip of nails at a time, then close the magazine. It will have a spring putting pressure on the nails, so it will have resistance on it and it will increase as you close it.
The oil gets dripped in the air hose connection on the gun before you connect the air. Make sure that this gun actually takes oil, some newer guns are oilless.
Hope this helps,Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 10, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
Why does my porter cable nail gun FN250B shoot
check the magazine bolts are tight and that the magazine is snug aginst the nose. also be sure you are using 16 gage brads and not 18 gage
Jan 23, 2010 | Porter Cable Air Tools & Compressors
How do you close the magazine on a bostitch sx150
once the nails are in place, slide the slide forward and you may have to press in the same button you use to open the magazine to get it closed the rest of the way.
Dec 05, 2009 | Stanley Factory Reconditioned Bostitch...
Will work fine for one or two nails and then nails jam in the gun or it shoots two or three at once.
This is iffy... but PC nailers are nit picky. If you used someone elses nails, it can (and will) jam and mess up.
So, if Porter Cable nails are being used, clean and lube the nail shoot (with a few drops of air tool oil).
If that does not work, Invest 19 dollars in a new, 18 guage nailer at Harbor Freight. I have 2 of those and they have been trouble free for 3 years.
Nov 15, 2009 | Porter Cable 1" 18 Gauge Brad Nails...
PC nail gun does not work all the time. nails do
You have to oil the nailer with pneumatic oil, or you're using the wrong size nail
Nov 10, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Dewalt cordless nail gun fires but doesn't seem to feed the nails very well, alot of misfires.
Try another brand of nails -- maybe your gun doesn't like those. Also, blow any dirt out of the nail magazine.
Sep 25, 2009 | Dewalt DC616kn 18 - volt 16 - gauge...
May 20, 2009 | Stanley Bostitch BT200K
Tools & Hardware - Others Logo
799 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
Joe Garcia
Joe Garcia
Roger Paull III
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
