Question about Kohler Plumbing
Collet on Kohler kitchen sink hose will not move at all so cannot disconnect leaking hose
Posted by Patricia Gamon on
ray gallant
    Top Expert:
  • Kohler Master
  • 67,963 Answers
Call a plumber
Posted on Aug 20, 2018
5 Related Answers
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: Low flow from Kohler K15160 spray kitchen sink
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
Posted on Mar 04, 2009
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Mar 19, 2010
Freddy
  • 1311 Answers
SOURCE: how do I tighten a
There should be a large nut underneath the countertop, this may have loosened up. You will need a basin wrench, which will allow you to get into this tight area. Once you have the basin wrench engaged, turn the nut clockwise to tighten.
Posted on Oct 19, 2010
lohrm
SOURCE: i have Geyser Kitchen Bar Sink/ Spray Faucet and i...
I have a Geyser GF8 that also leaks at the turning joint. Anyone know how to dissamble one of these faucets?
Posted on Oct 30, 2010
shadows865
shadows865
SOURCE: How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Posted on Aug 14, 2012
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: Fort® Single-control...
How do I disassemble a Kohler kitchen faucet
Remove sprayer and hose from faucet body.
Remove handle and cartridge.
Pull up on body.
Replace parts and reinstall in reverse order.
Aug 31, 2014 | Kohler Model 10433: Fort® Single-control...
How to stop sink leak
Check whether the faucet is leaking or the drainage is leaking.
If the faucet is leaking, you need tools to loosen the faucet to check whether the hoses are leaking or not. If the drainage is leaking, you can tighten the slip nut.
May 04, 2014 | Kohler Model 10430: Fort® Single-control...
Replacing hose on a Kohler model numbe K- 10433
http://411plumb.com/kohler-forte-faucet-troubleshooting-repair-guide/
Mar 11, 2014 | Kohler Model 10433: Fort® Single-control...
How do I replace a hose diverter in a single handle Kohler kitchen sink?
Yes, contact Kohler and they have a site you can watch that should be helpful.
Jan 11, 2013 | Kohler Home
The pullout spout leaks
pull out the spray part and tighten the nut around the hose or take it loose and replace the washer
Jun 28, 2009 | Kohler K-15160-7 Coralais single-control...
Srayer leaking down the hose from pivot joint near spray head
there is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
Apr 21, 2009 | Kohler Model 10433: Fort® Single-control...
Plumbing Logo
1,116 people viewed this question
Top Kohler Plumbing Experts
Mike
Bill Johnson
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
