Question about LG WM-2277HW Front Load Washer
How do i remove panel from front load washer
How do i remove the front panel of the washer to get to the motor to access this area for possible coins?
Posted by Karen Mack on
  • Karen Mack Nov 25, 2007
    the washer is a LG WM2277HW
  • Karen Mack Jan 04, 2008
    Thanks so much - this is great, exactly what I needed!!
Claudia Prince
    New Friend:
How to clean out hoses inside front of washer. code OE
Posted on Oct 31, 2011
Anonymous
You can download a basic but somewhat helpful service manual here http://136.166.4.200/contents/Laundry/WM2277.htm that has some disassembly instructions and exploded view diagrams, explains the troubleshooting mode.
Posted on Jan 04, 2008
How do I clean the trap filter inside my Electrolux Front loader
Good Morning Deanna - Sounds like you are speaking about the Coin Trap. Below are some basic troubleshooting steps you may wish to follow to clean the trap:
· Unplug the unit.
· Remove the bottom front access panel. There are two screws one on right and one on the left towards the bottom of the front panel.
· Now that the panel is removed look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
· Clean the drum out with as much water as possible that you can remove and have towels ready. The next step you will have the remaining water come out of the bottom of the drum and onto the floor.
· At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
· Reach inside the coin trap and clean what is inside of it out.
· Put the unit back together following the same steps backwards.
Hope this information proves to be helpful!
Jun 20, 2013 | Electrolux EW1000i Front Load Washer
Repair manual
Good Afternoon Brenda - Generally speaking, washer machines do not have a filter. Depending on your particular model the unit may have a coin trap. Below are some basic troubleshooting steps you may wish to follow to locate and clean the coin trap:
  • Unplug the unit.
  • Remove the bottom front access panel. There are two screws one on right and one on the left towards the bottom of the front panel.
  • Now that the panel is removed look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
  • Clean the drum out with as much water as possible that you can remove and have towels ready. The next step you will have the remaining water come out of the bottom of the drum and onto the floor.
  • At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
  • Reach inside the coin trap and clean what is inside of it out.
  • Put the unit back together following the same steps backwards.
May 14, 2013 | Frigidaire GLTF2940ES Front Load Washer
My LTE5243D top load stacked washer is about 10 years old. How do you take the front panel off to access the washer's motor coupling?
To gain access to the washer components, the front panel between washer and dryer must be removed first.
Remove the two top screws securing thethis panel to the unit.Tilt the transition panel down and pull itstraight out.Remove the two screws located behind the washer top.Pull the washer top forward to disengage the top locks. Disconnect the washer lid switch harness. Lift the washer top off the unit.Remove the two screws from inside the top of the washer front panel.Lift up on the front panel to release the catches near the bottom of the panel andremove the front panel.
Apr 24, 2012 | Whirlpool LTE5243D Top Load Stacked...
My washer wont drain and i cleaned the drain tube. what else should i check or replace to make it work?
Remove as much water from the tub as possible. Remove the three screws from the bottom front of the washer. You may have to tilt the machine back to get access to the screws. Remove the lower panel. Right in front is the clean out for the pump. Have several towels or a shopvac ready to catch the water. Unscrew the cleanout from the pump. Remove all the coins, lint, hairpins, bra wires and other debris that has accumulated in the trap. Reassemble and test.
Mar 05, 2011 | Whirlpool GHW9400 Front Load Washer
How do you get the front panel off of a Frigidaire Washer Model ATF8000FS1 to get at the coin trap?
The 7000 model and probably yours too, does not have a small front panel at the bottom that comes off. You can't access it from the back. The four screws at the bottom of the full front panel come off-- then go to the back and take off the top. Remove the screws at the detergent/softener drawer, and take it out-- remove the screws on the control panel and it can lay on the top of the machine... you can then get at the top screws on the front control panel... remove them and before taking it completely off... remove the contacts in the right side of the door by removing the two stainless screws similar to the ones removed from the detergent drawer. You should be able now to pull the front panel to access the boot.. Be sure to pull out the coin trap fully and rinse everything out... when putting it back be sure all the clamps and brackets are replaced properly or it will leak.
Jan 08, 2011 | Frigidaire ATF6000ES Front Load Washer
Where to find the coin cup on the front load fridigiaire washer, to empty
there is none just a large hose from tub to pump . Remove the lower front panel and you will see. If no front panel remove the access panel in the rear.
Nov 20, 2010 | Frigidaire ATF6000ES Front Load Washer
Hi, have just purchased a bosch model was28440au, had been working no worries at all until this evening when i spotted a ten cent coin in the drum wedged in between the small inner seal, I had to let it...
hi .it might be likely that the coin is stuck in the pump .to access this you need to open the panel at the front and open it panel.see pic.please note that some water will come out when you open it.put a big towel in front.of it..
Jun 12, 2017 | Bosch Axxis WFL 2060 Front Load Washer
How to fix a drain error in washing machine
The first thing to do is to check/clean the pump filter...Access this via the small door at floor level..remove as much water as possible first, because once you remove the pump cover any water in the machine will drain from filter area...Leaning the machine back can help..Remove and clean the filter...Check that coins are not preventing the impeller from turning.....Good luck...Nomess
May 23, 2010 | LG WM-2277HW Front Load Washer
LG front load washer A coin fell in between drum and housing.coin rubs on drum while spinning. how do you access the area between the drum and housing?
take off the front panel
on the bottom/front of the drum is the heater- held in with 10 mm nut - slacken the nut- this will loosen the heater in its holder- pull out the heater- this gives you access to the bottom of the tank
Jul 16, 2009 | LG WM-2277HW Front Load Washer
Front load washer- coin removal
Hi, The coin is probably inside the baffle that tosses the clothes around. I believe this nodel has a screw that holds the baffle in place. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 28, 2009 | GE WSXH208A Front Load Washer
LG WM-2277HW Front Load Washer Logo
287 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
