Question about Crate Music
I have a Crate BT220 that powers on, pre amp out works, but nothing from the head itself.
Posted by John Quave on
1 Related Answer
Fred Yearian
  • 5603 Answers
SOURCE: Crate bass amp bt220 limit led is flashing
You can reach the limiting IRRESPECTIVE of where the volume control is set when you have a guitar or other source that has HIGH output.
Guitars that have battery in them with internal amplifiers are an example of a high output guitar. Plain inductive pickups may require the volume control to be set at say 70% to reach limiting.
Please NOTE that the volume control is NOT linear, but is an "audio taper".
Limiting means you are probably driving it too hard. Many learn the hard way when speakers and thee power amp fail.
When the cone is driven too far beyond the pole pieces of the magnet, then the IMPEDANCE of the speaker becomes relatively low and can damage the power amp. The limiter tries to prevent this by sensing the current and or voltage and will back off the gain internally. This causes distortion when it happens.
Posted on Dec 14, 2009
Crate power head replace fuse how to /
did it blow a fuse or is it just dead?
Aug 02, 2014 | Crate Music
Crate amp head loose spring
its the reverb tank spring, look where it is connected on the other side. this will give you an idea as to where it was connected. solder it back on.
May 10, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
Crate pa6fx powered mixer, powers on but when I hook speakers up to them, hear loud hissing and pops out of one of the speakers, nothing out of the other. I can hook up a mic and hear myself through the...
It is likely that there is a failure of one of the amps in the unit. It could be a cracked circuit board, bad solder, bad volume control, or a bad compnent in the power amp section for one side. HOWEVER something does NOT compute here as you can't connect more than one speaker to a 15 Watt Crate amp... Maybe you have two of these amps.
Dec 27, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a Crate PA-8 4 ohm 150 watt PA head that I run to four Peavy 10" PA speakers (two per side in series). It was very good, clean sound, but the speakers were cheap and may have been pushed too hard -...
150 watts should be easily handled by four Peavey speakers in the connection you described.. If the Peavey's are 8 ohms, then your total load was 8 ohms for the series/parallel arrangement which is well within the 2 ohm drive capability of the Crate according to specs.
I question if you really mean the speakers were in series? This requires a special cable to do this. Now if you mean they were "daisy chained" like the amp went to one speaker and another cable connected that speaker to another, then you REALLY had ALL speakers in parallel electrically which would be at the 2 ohm low limit of the amp... In either case, with only 1/4 of the 150 Watts to each, the speakers should NOT have been damaged. The amp MAY have been damaged. Try each speaker individually at a REASONABLE level to test.
If you plug into the effects loop out jack,OFTEN the connection to the internal power amp is broken so you might have to arrange a special cable as a wye to go back into the power amp as well as your external amp. In any case pwere ALL interconnected amps, etc from the same power source/receptacle for system safety.
Jul 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate bass amp bt220 limit led is flashing with the volume only at half
Dec 14, 2009 | Crate Music
I have a crate PA 8 and it makes a crackling noise when I play through it. I hooked the speakers to my other amp and they sound good, I hooked the PA to my marshall cab and it still has the noise, so I...
Hi
The problem is with the amplifier itself. Crackling is usually capacitor related and you will need to have the amp checked over to properly identify the cause.
Some amps are also prone to pick up static from other electrical items which can also cause these problems. I had a crackling issue with an old Crate amp of mine which turned out it was due to being too near a computer/monitor so it is worth eliminating these things as a possible cause before having the amp checked.
Hope this helps. Thanks for using FixYa.
Oct 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate V16 1X12 Palomino loses power, guitarist robbed of fame
Start easy. You could have a bad power switch. Do you get any kind of indication of any life at all, like tube filiments or front panel indicators? If the fuse is blown you have a fault that is drawing excess current, in which case you can check the rectifiers that create your bias voltages, yank the output tubes to see if they have an internal short, less likely would be a shorted filter capacitor (although I have seen it). You could also have a bias problem on the output tubes that causes them to draw excess current and likely makes the tube(s) glow bright red before popping the fuse. If this is the case, look for shorted or leaky coupling capacitors and burned bias resistors, or maybe just a tube with internal shorts, and you will likely have junk tubes as a bonus (they don't take kindly to glowing bright red- meaning a glow that is far more intense than the soft glow of the filiments). If the fix gets more involved than all of this, give me your email addy and we can get hard core.
May 16, 2009 | Crate Music
Crate tube amp will not power up but cooling fan tries to run
Yes.
Are you saying that the only indication that it is running at all is that the fans are running? So the tubes don't light up? No indicators on the front of the amp?
Power supplies that provide multiple voltages, which your amp has, can provide some of the voltages while having a problem that prevents them from providing others, all while not blowing a fuse. If you are not confident in your ability to work on a piece of electronic equipment that has 120VAC coming in and at least 175VDC or more present inside it, bring it to a service center.
The good news is that it is probably not horribly serious. Problems like this can almost always be repaired in a cost effective manner.
Feb 11, 2009 | Crate Blackheart BH15H Handsome Devil...
Music Logo
Top Crate Music Experts
Ngoro
Are you a Crate Music Expert? Answer questions, earn points and help others
