Garmin GPS is the most accurate Geo-tracking device, that gives a perfect map and tracking serves to users. For the users who have issues in changing the language or keyboard settings, please follow the following guidelines carefully:
1.First of all, go to the settings and click on 'Language and keyboard' setting.
https://www.ithelplinenumbers.com/garmin-customer-support-number
2.Here you will get the options like:
·Voice Language: It will set the language for voice prompts.
·Text language: This will allow you to set the language for on-screen text data.
·Keyboard Language: It will change the language for the Keyboard.
·Keyboard Layout: This will allow you to reset the layout of your Keyboard. You must select the right option to change the language setting to your desired language.
If you still having some issue, then you must contact to Garmin GPS Customer Support number +1-800-596-2947 (toll-free). These technicians are available 24*7 to take up all your queries and issues. They are highly educated and well experienced to rectify any issue within a few minutes.
SOURCE: Describe your Garmin nuvi® 205W Car GPS
Turn unit on, hit i agree when prompted. Push tool icon in lower right hand corner. Then press settings icon, scroll down to language, there it have voice, text, and key board, you may be able to hit restore in the bottom right corner or you can set each seperatly. If its in Portugese it will say Deinicoes not settings, and Idioma is language, then texto for text. Restaurar is restore. Sim is yes.
SOURCE: Garmin GPS Model 205 - does it give street name?
I don't believe this unit offers a street name function. The hard drive is not powerful enough.
SOURCE: tomtom GPS language setting
Do this whilst it is disconnect from a PC
Whilst it shows a map display touch the screen once.
Select the icon that looks like a spanner / wrench
Use the rght arrow on the display until you see a bunch of flags. (if you shoot past it just keep going until it comes ound again)
Touch that and select the correct the correct flag / language.
SOURCE: i need to change the language on my my garmin nuvi
Garmin uses picture icons for most of the settings. When you forst turn the unit on you will see a magnafine glass map speaker and wrench. the wrench is tools press that. the next set of icons you will see another wrench that is settings press that. The next set of icons there will be a pair of lips that is language press that. The next screen is harder this is the language screen the upper left blue button is voice, the spoken directions, the upper right is text, the one you need to change, the lower left is keyboard. Select the text button, the languages are alphabetical so scroll up to american english, the screen will refresh then press ok.
The other solution is to do a hard reset. It sounds like you got this unit used or a floor model that someone changed the language on. It might be in your best intrest to reset to clear all saved info that others have input.
SOURCE: language setting wrong on Garmin Oregon 400t
1) Go into setup. This is the icon that looks like a wrench.
2) Use the arrow buttons to scroll up to the top of the list
3) Select the second item down (GPS will be the first item)
4) Scroll to the top and English should be at the top of the list.
