Question about home Audio Players & Recorders
Operation manual for a hts 1000 home surround sound system
Posted by Matt Robinson on
5 Related Answers
Anonymous
  • 1067 Answers
SOURCE: Television surround sound problem
well u have to use tv rca out to a input on this system ok then select input 1 aux in ect on sound system ok
Posted on Feb 02, 2008
Anonymous
SOURCE: needing a remote control for a ht3915 home theater surround sound
code for dish remote to control DYNEX LTDVD20
Posted on Mar 15, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Anonymous
SOURCE: SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
how can i listen to my ipod through a samsung lcd tv
Posted on Sep 13, 2009
Anonymous
SOURCE: How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
Posted on Jul 22, 2010
HAVE A CRAIG SURROUND SOUND HOME THEATER SYSTEM WITH A DVD PLAYER HAVE GOOD SOUND BUT NO PICTURE WHEN PLAYING DVDS
Check whether you have connected your HTS video out put to TV/PROJECTOR 's Video input. Try HDMI port for better result.
Oct 31, 2013 | Craig 5.1 Surround Sound Home Theater...
Lg HTS how do i change from stereo sound to Surround. The rear and centre speakers are not working at present
Music only plays through those two speakers, only movies with 5.1 format will play through all your speakers
Sep 18, 2012 | LG 5.1ch 1100w bluray hts 5 speakrperp...
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
May 25, 2010 | Philips HTS-3555 System
I cant get the surround sound to work with the tv stations but it will work with DVDs
Not much detail to work with here. Your cable box (?) should have a digital audio output. Use it if your HTS has an input for it. Otherwise, analog audio from the box or TV won't produce true surround, but most HTS can simulate it.
Jan 10, 2010 | Panasonic Home Theater System System
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Jan 08, 2010 | Sony DAV-S300 System
HTS-GS1 Surround Sound System cannot be utilized for tv.
Check Your TV audio setup,many TV makers out there would like you to turn off the tv speakers in order to use the external speakers.
Joe
Feb 03, 2008 | Pioneer HTS-GS1 Theater System
Feb 02, 2008 | Pioneer HTS-GS1 Theater System
No surround sound for TV
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Nov 18, 2007 | Philips HTS3400/37B System
73 people viewed this question
Top home Audio Players & Recorders Experts
Kenneth Walker
Marvin
Marvin
Are you a home Audio Player and Recorder Expert? Answer questions, earn points and help others
