SOURCE: LCD - Focus
DSLR camera was not made to be used as a point and shoot camera and you cant preview the shot before taking a picture. You are to use the eye piece to focus right. Also before taking a picture, push the exposure button just a little to let the camera focus right.
Posted on Jul 25, 2008
SOURCE: cannot take pictures thru lcd screen on d40x DSLR
The D40x is not capable of Liveview - i.e. looking at the LCD to take a picture. You are mistaken.
If you want Liveview, you need to buy the D3 or D300 cameras. The D40x is an entry-level camera.
Posted on Jun 30, 2009
SOURCE: Sony 200 manual
dont even try to do this yourself send it back to sony let them do it,,, the lcd is very very easy to crack if you dont take geate cear and for what they cost, is it worth the risk???
Posted on Oct 24, 2009
SOURCE: replace LCD monitor on Sony DSLR a350
The You-Tube video is useful. http://www.youtube.com/watch?v=dP0Yr4YXM9Y
Care must be taken when removing the ribbon-cable connector from its mating half on the camera ribbon-cable.
The black strip on the mating connector has to be flipped back, away from the display ribbon, to release the display ribbon.
Then after locating the new ribbon fully home, the same black strip has to be flipped forward in the direction of the display ribbon and pressed down to clamp this connector in place. All this is shown, but quickly in the video.
Do not touch the bare surface of the new display or the inside surface of the removed display protective surface which has an optical coating which easly shows fingerprints.
Posted on Sep 02, 2010
SOURCE: need to replace the lcd
http://www.docs.sony.com/release/DSLRA330.pdf
Ok to assist you please find above your user manual, below a link for your service and repair manual.
http://www.nodevice.com/manual/sharp/ERA310-A330_SM_GBpdf/get42785.html
Below is your support link to Sony.
http://esupport.sony.com/US/perl/support-info.pl?&info_id=589&mdl=DSLRA330
usually you can buy replacement Kits for replacing the LCD, IF available, they all usually come with tools to do the job, and brief instructions on how to do it. Ebay often has these kits.
The service manual is a must have at any cost when attempting to repair as it shows one how to repair replace all things.
Posted on Nov 25, 2010
