Question about Furniture
Need to know how to reassemble Ashley brown leather sectional sofa, had recliners with storage unit
Have all the parts but do not know the order of assembly
Posted by Peter Mueller on
3 Related Answers
Anonymous
  • 448 Answers
SOURCE: need illustrated parts breakdown for 2000 ford
Go to dealer and get print out from parts department
Posted on Aug 09, 2009
billy bob
  • 47 Answers
SOURCE: Does gm recommend sectioning right rail assembly.
it doesnt matter if gm recomends it...if the insurance company wants it replaced than an icar certified welder should know what to do...with out replacement of full rail then your insurance doesn't have liabilty if some one gets hurt later in another accident because a structural component wasn't replaced when they recomended it...It needs to be replaced properly collision shop cannot cut rail below tolerances everycar is engineered to crumple ..and they layer the rails to provide safety in the event of a collision....creases can be straightened in certain locations but rails need to be spot welded to increase strength...a certified autobody welder will not cut a rail, instead he will drillout the old one andplace in the new one.. i dont recomend they cut and mig without a manufacturers consent...you should consult a dealer with experience in collision repairs ...dont give consent for an improper repair to make the shops life easier or cheaper...because the liability becomes yours....
Posted on Jun 28, 2011
Testimonial: "Thanks alot. Your information really helped."
Bill Boyd
  • 53816 Answers
SOURCE: How to reassemble a cobra 8000 staple gun
go google and type in --- schematic /parts diagram for cobra 8000 staple gun-- there may be a pdf version to down load
you may find a manufacturer site with a contact number / e-mail that you can contact
Posted on Nov 20, 2016
Can I purchase a plastic gear for a Apex AP a88 motor?
Apex Reclining Motor Model AP A88 ' eBay
m.ebay.com/itm/201272942152?cmd=VI_SPR
Apex reclining motor- model- AP-A88 in Home & Garden, Furniture, Sofas, Loveseats & Chaises ' eBay.
Jan 04, 2015 | Furniture
Ashley furniture reclining loveseat power cord
Many of their power supply parts have changed requiring all electrical parts to be changed out. I might have a slightly used one if I know the numbers on the part. If not you can call Ashley customer service and request new kit for around 200. You need the serial number on the bottom of the chair.
Jun 02, 2014 | Ashley Furniture EXHILARATION 2 SEAT...
While removing spot from sofa, also removed color and now have lighter section where spot was. What leather color product should I use to match the brindle color and correct the problem?
You can use a acrylic dye from a leather store. You will need to top coat the leather again but it is available in aerosol too. You have broke the original color so dab on the color,allow dry time then 2-3 topcoats (light sprays)
Apr 26, 2014 | Ashley Furniture HOUDINI RECLINER SOFA...
Need switch for Ashley recliner P/N AP-W61
I have 2 of the AP 61 switches available Please contact me
Feb 01, 2014 | Ashley Furniture Ashley 4240186 Reclining...
How to change motor
You need to replace the complete drive assembly. If you can find a serial number you might be able to get them from Ashley. They have redesigned them so yo will need to replace both drives, power unit and switches.
Mar 22, 2013 | Ashley Furniture Ashley 4240186 Reclining...
Two out of 4 handles to recline have snapped off from the wire. Where can I get replacement parts
ebay has cables for sale, easy fix ... flip the sofa over and look for the cable follow it to the recliner should be a screw holding it on the frame undo the screw and remove the cable
Sep 25, 2012 | Simmons Upholstery Halifax Bonded Leather...
Furniture Logo
161 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
