Question about Kwikset Locks & Locksmithing
How to fix keypad light on a 913 kwikset smart lock
Posted by wendell miller on
5 Related Answers
Anonymous
SOURCE: i have a smart key kwikset lock and i used the
original key or new one dont work now how to fix this please , i have the smart key kwikset.
Posted on Oct 12, 2009
Anonymous
SOURCE: smart key kwikset lock stopped working with the key.
I have just experienced the same problem. After 4 calls and an hour on hold, a warranty representative is going to send me replacement cylinders. I am not happy since 3 of the 4 locksets are already installed. My wife and daughter were locked out for 3 hours!!! Would not recommend this product!
Posted on Feb 01, 2010
Anonymous
SOURCE: kwikset smart code touchpad electronic deadbolt
I have the same problem, electronic locking system went dead but still beeps, stuck using keys now...according to the kwikset website though it says "Warranties cover the original residential user of Kwikset Products against defects in material and workmanship as long as the original user occupies the residential premises upon which the product was originally installed." so hopefully they will fix the problem
Posted on May 30, 2010
Coaltowner
  • 963 Answers
SOURCE: Kwikset keypad deadbolt will not lock or unlock.
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Posted on Apr 18, 2011
Coaltowner
  • 963 Answers
SOURCE: My numbers on the keypad are worn off of my
Contact Kwikset Customer support:
http://www.kwikset.com/Customer-Support/Overview.aspx
good luck!
Posted on Nov 05, 2011
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
My keypad won't light up when door is locked whe you push lock won't light up green
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Kwikset keypad deadbolt will not lock or unlock. Batteries OK.
Apr 10, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The keypad stopped working. I replaced the batteries and it beeps, but the keypad is still not working - random beeps, but when I try to reset there is no response.
I did not find any direct information or solutions on the Kwikset web site, so I suggest that you contact them directly. Here is the contact link:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625)
Feb 10, 2011 | Kwikset 90711P Venetian Bronze SmartCode...
Lock won't work. Our unit became sluggish. We changed the batteries, but now it won't lock or unlock using the keypad. Help.
Kwikset has a lifetime mechanical and finish warranty. Contact them from here:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Dec 18, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
The backlights on our Kwikset 909 are not lit. Is this controlled by one of the switches or could something not be installed correctly?
Dec 17, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
The back light is not working on our kwickset keypad smart controller.
When your door is locked, you must hit lock again before entering your code. After you hit lock the second time the LED back light will come on.
Dec 31, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Keypad doesn't light up.
If this is a battery operated lock then the backlight doesn't stay on (otherwise it will wear the batteries out). To make the keys light up when you want to enter your code you have to push the lock button on the keypad first. If the keypad light has never come on then open the door and manually lock the interior lock then press the keypad lock button then the above instructions will work. This is the solution I got from Kwikset customer support and it worked for me. Hope this helps you.
May 19, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
Kwikset smart code touchpad electronic deadbolt
Oct 12, 2008 | Deadbolt PFK Touchpad Electronic Lockset
Locks & Locksmithing Logo
1,371 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
