Question about Taylor Measuring Tools & Sensors
I need operating instructions for a taylor 5212 meat thermometer
Posted by Wade Dahlen on
Mark Cheong
    Master:
  • 791 Answers
First, I'm not a Taylor representative.
* Check your warranty. Call for support
* Contact; 1-800-289-0944
* WWW.taylorusa.com
*** The following is for information only.***
* Are you sure about the model "5212"?
* LED Meat Thermometer; https://www.youtube.com/watch?v=v6okAYWECvQ
* Manual (1487); https://www.wholesalepoint.com/documents/Taylor-1487.pdf
* Unboxing (1487); https://www.youtube.com/watch?v=SagK4czbaF4
* True Temp; https://www.youtube.com/watch?v=S9mLBcW2R_k
Aloha, ukeboy57
Additional (related) Information;
* Dial style; https://www.youtube.com/watch?v=OgrSqFR0x9o
* Brochure; http://taylor-enviro.com/media/lit/2014-ProKitchen-SellSheet.pdf
* Specs; http://www.lesman.com/unleashd/catalog/thermome/Taylor-dial-thermometers/tay_pockets.pdf
* Using meat thermometers; https://www.bhg.com/recipes/how-to/food-storage-safety/using-a-meat-thermometer/
* Calibrate; https://www.youtube.com/watch?v=gfx2zJP0QTw
Posted on Aug 18, 2018
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: I have a Sunbeam digital
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Posted on Oct 09, 2010
Coolasaurus
SOURCE: Can't reset Taylor 5367 indoor/outdoor thermom
I changed the batteries on mine and it reset itself. That was easy.
Posted on Aug 19, 2011
Anonymous
SOURCE: Polder 891-90 Where can I get
Polder timer manuals appear on following link:
http://www.polder.com/productinfo.html
Typical 891 manual:
http://polder.com.p2.hostingprod.com/images/instructions/891_instructions.pdf
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 28, 2011
Anonymous
SOURCE: I have a polder digital thermometer with two
Timer is not identified for certain.
1) Some Polder timers have in-oven thermometer, and others say not to use thermometer inside oven.
2) The 12453 dual-sensor says inside-oven is ok
3) The 894 dual sensor says inside-oven is ok
4) TM360 dual probe says inside-over is ok
breezyken
breezyken
SOURCE: Taylor 1542 wireless thermometer - how to install remote batteries
Flip up the curved cover latch and then pry open the top of the battery compartment cover with a long fingernail, small screw driver or coin. I agree it could be easier.
Posted on Jan 24, 2012
My Taylor 1479 is reading a temp of 263 in a room temp environment. when i reset it and plugged it back in it is registering 260-270? Anyone know why and how to fix this?
put probe into boiling water - it must be close to 212°F - if not u need a Taylor expert - and more info - the easiest thing to try is another probe, or plug ur probe into another base.
Jan 24, 2015 | Taylor Commercial Wireless Remote...
Installed new batteries, but need instruction to reset temperature readings
Type "Taylor 1524 manual pdf" in google. That should pull up your manual. Sometimes companies produce the same item, with just subtle changes (product differentiation) i.e. Chevy used the same motor block for the 327,350,400 chevy motors, and just installed different cylinder heads.
Apr 22, 2014 | Taylor 1524 Wireless Indooroutdoor...
Can someone give me instructions how you use a meat thermometer?
Watch this video from Video Jug - it's gives good instructions for a food thermometer;
http://www.videojug.com/film/how-to-use-a-meat-thermometer-2
Feb 14, 2013 | Health & Beauty
Need instruction manual
www.taylorusa.com/media/IBs/1524_ib.pdf
Sep 24, 2011 | Taylor 1525 Wireless IndoorOutdoor...
Can you give clear instructions on to use the weber pocket thermometer.The instructions i got with it i find are not very clear;and could you tell me the proper temperature for all the various meats.Thank...
Here's the general rule of thumb for cooking temperatures for meats. Remember though, you cannot leave the thermometer inserted in the meats while cooking. It's only for Instant Read.Always insert it in the thickest part of the meat away from any bobes.
BEEF RARE 14=30 - 140F
Jul 30, 2011 | Weber-Stephen Products Weber Digital...
I bought a Taylor Weekend Warrior digital thermometer 806E4L. Did not receive any instructions.
You can download the Instructions from Taylor's website: http://www.taylorusa.com/media/IBs/806E_ib.pdf
Dec 18, 2010 | Microwave Ovens
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
Measuring Tools & Sensors Logo
442 people viewed this question
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
