Question about Vulcan Heating & Cooling
I have a Vulcan heater, that has been working fine. The pilot light went out. I have managed to get it working again. But now the heater will not light up. When I turn the knob for some heat, nothing happens. Please can you help?
Posted by Dean Huddle on
john h
    Top Expert:
  • Vulcan Master
  • 23,515 Answers
Check and test thermocouple
Posted on Aug 18, 2018
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
Posted on Jun 18, 2008
Anonymous
SOURCE: Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Posted on Aug 03, 2008
Papa0106
  • 13 Answers
SOURCE: Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Posted on Feb 28, 2009
clay
  • 74 Answers
SOURCE: AO Smith water heater won't fire.
I bet your thermo couple is bad or your ports are clogged? How old is the unit?
Posted on Apr 16, 2009
Anonymous
  • 540 Answers
SOURCE: williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Posted on Dec 22, 2009
How do you light the pilot light on vulcan compact 60? there is no ignotion button to be seen
hi chris, did you work out how to light the pilot light! the instructions are great until it says light the pilot.... yeah, but where is the pilot light?? it is easy to find when it is on... but not obvious when off... i\'m pressing the button in for 15 seconds and then waving around a naked flame... it just doesn\'t feel safe after 30 seconds of gas wissing and no joy... plus i\'m in a crawl space under my apartment covered in spider webs - i\'d love another clue so i can get out of the crawl space quicker ;-) thanks ren
Jan 15, 2013 | Heating & Cooling
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
Vulcan wall heater gas issues...
The igniter may be bad and needs replacing.
Jul 01, 2017 | Vulcan Heating & Cooling
I have purchased a house with a Vulcan gas space heater. The pilot light was on but since the gas was temporarily turned off I can not turn on the pilot light. I am in Adelaide South Australia.
you have air in the gas line , the pilot being so small it would take ages to come through , you need to purge the line to get the air out , se if you can undo the pilot line to pruge it
Oct 14, 2010 | Vulcan Heating & Cooling
Can't seem to ignite pilot on a 30 year old vulcan heater. Same problem every year as winter is approaching :) Usually works fine once pilot is on though.
It's probably just a dirty pilot orifice (or a spider web), if it's been off since last winter. Try using a can of compressed air with attached straw (like you use to clean computer keyboards) and blow out the dust from the pilot orifice in the pilot assembly, which is where you light it. That should do the trick. Good luck! Douglas
Jun 07, 2010 | Heating & Cooling
Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Error code f1 on vulcan basic deluxe
Ck and ensure there is a pilot light.No pilot light, no gas.
May 26, 2009 | Heating & Cooling
Aug 23, 2008 | Heating & Cooling
Jul 08, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Vulcan Heating & Cooling Experts
Paul Carew
Vernon Taylor
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
