Question about Maytag Refrigerators
The problem is probably the starter asm. on the compressor, though it could be signs that the compressor is failing. An amp draw test would be a good place to start
Posted on Aug 19, 2018
SOURCE: Maytag fridge made some clicking noises and then stopped cooling
For what it is worth. I had this problem twice and both times the compressor ad to be replaced. Ton this day it sounds like a pin pong game whenever it runs. No it is not the fans or the ice maker.
Posted on Feb 13, 2008
SOURCE: maytag refrigerator clicking
it sounds like
a bad:
the start
switch clicks off usually when the compressor is pulling too
many amps or the compressor is overheating. if the compressor is not even
running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or
the start switch is bad and cannot handle the amps required to start the
compressor.
Posted on Jul 06, 2008
SOURCE: GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Posted on Jul 26, 2008
SOURCE: Maytag MFD2561HES Reefer not cooling
hello frooska,
kindly look at the back panel of the freezer section. if you can hear the humming sound, find out where it is coming from. if the sound is coming from the compressor, that means the evaporator fan is not running.
but, take note that u need to press the door switch of the freezer in order to check the fan. the fan stops every time the door is open. if the fan is not running, you have to remove the middle panel, above the evaporator, the fan would be there. ( in the freezer section)
but if the fan is running and the back panel of the freezer is full of frost, then that would be a defrost issue.
defrost heater, bi-metal or defrost controller.
Tnx 4 uisng Fixya,
Drcool
Posted on Dec 17, 2008
SOURCE: Maytag Performance Side by Side Fridge Freezer is not cooling...
sounds like a bad compressor.
Posted on Jan 09, 2009
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
Jan 31, 2010 | Refrigerators
Dec 29, 2009 | Refrigerators
Oct 19, 2009 | Maytag Refrigerators
Sep 16, 2009 | Refrigerators
Mar 18, 2009 | Refrigerators
Feb 15, 2009 | Maytag Refrigerators
Dec 16, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Jun 21, 2008 | Maytag Performa PAV2200
Sep 16, 2007 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
98 people viewed this question
