Question about Krups KM7000
I have a grind and brew Krups but it is not grinding. My husband tried to take it apart to find out the problem, but it is not a normal screw, it's a triangle. Does anyone know where i can find the right tool to fix this?
Posted by brisachj on
Anonymous
    New Friend:
  • 17 Answers
I used a small bladed regular screw driver to fit into the triangle shaped screw head.
Posted on Dec 22, 2009
Anonymous
    Scholar:
  • 22 Answers
You can also grind a regular Philips-head screwdriver into the right 'pyramid' shape.
Posted on Jan 31, 2010
Krups ea 8250
If it doesn't grind , than there is no coffe , it will surely come as water .
Grind it first , and than brew the coffe .
Oct 24, 2013 | Coffee Makers & Espresso Machines
This is the Krups Grind and Blue Coffee Maker purchased from Amazon 7/8/11. It is the second one I purchased. Krups factory service AND local service station phone lines are constantly busy. On this...
Sorry for the delay. I will need to look up some reference materials and drawings on this before I can aupply an acurate answer. Been one of those nights and I apoligize for the delay.
Sep 30, 2011 | Krups KM7000
Krups xp9000 will not brew, but grinds beans.
I also have the same problem with my xp9000. The beans are grinding but no coffee is expressed.... Any advice????
May 14, 2010 | Krups Super Automatic XP 9000 Espresso...
My Cuisinart Grind and Brew has begun leaking water underneath the unit as it is brewing.
I also have the same problem with water leaking out of the bottom.There is a defective hose underneat the burner plate (dry rotted)Mine is manufactured in 05.We contaced Cuisenart to make them aware of the problem and they told us nothing they could do it was out of warranty.After talking to 3 of there costumer service reps.my husband decided to take it apart and found the shredded hose leaking water on the electrical wires.That is why we contacted the CEO of the company and The Consumer product safety commision..They are handeling this issue.You can contact them also .
Mar 07, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
Nov 20, 2009 | Krups Coffee Makers & Espresso Machines
Espresso brews too fast on Krups XP4030
Check/adjust the grind on your coffee.
Jun 21, 2009 | Krups XP4030 Espresso Machine
Krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
May 25, 2009 | Krups Coffee Makers & Espresso Machines
Krups Grind & Brew KM7000
if you dont have something jamming the grinder look like blow grinder motor you can trie activate the grinder at the same time gently tap the side off machine maybe what ever blocking the grinder gonna come off if not tank good for warranty good luck cheers
Jan 17, 2008 | Coffee Makers & Espresso Machines
Unable to make coffee automatically using whole beans
One thought is to call Capresso for the recall to fix electrical cord. They will pay shipping both ways and fix any problems for free as part of the recall. Worked for me, might be too late now but worth trying.
Nov 17, 2007 | Jura Capresso C1000 Espresso & Coffee...
Krups KM7000 Logo
470 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
