Question about Golf
I have a Club Car Golf Cart, does Serial Number RE0420-393208 belong to it?
Posted by Rick Johnson on
john h
    Top Expert:
  • 23,515 Answers
Dont know is that the number on the plate
Posted on Aug 16, 2018
5 Related Answers
voodoomox
marlon john madrid
  • 1689 Answers
SOURCE: wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
Posted on Jul 24, 2008
weblord
William Nabaza
  • 507 Answers
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Posted on Oct 18, 2008
Anonymous
SOURCE: complete wiring diagram for a 1990 36volts club car golf cart
http://cartaholics.com/forum/index.php?showtopic=1880&hl=green+wire
See if this helps. Good luck!!
Posted on Jun 30, 2009
Anonymous
SOURCE: Need a schematic for a club car golf cart
new batteries-36 volts--can,t get power to motor------ help please
Posted on Dec 19, 2009
golfcartman
  • 34 Answers
SOURCE: club car golf cart intermittent no spark
What you have is a bad ignitor. It is a small part located behind the RPM limiter. Getting to it is a little tricky but I will try to explain. On the front of the motor, you will find 2 10mm bolts holding a black object that is the RPM limiter. Take these two bolts out and you will find the silver part behind the black box. It will have one wire running to it. The reason it is intermittent, is that heat from the engine builds up and the heat causes it to be bad. When it cools down, it will go to running again. The part runs about $50-$70 . Replace and make sure the connection fits snugly and that the wire that was under one of the bolts goes back on.
Posted on Apr 22, 2010
1987 owners manuel for a club car golf cart
Club Car Manual Club Car Serial Number Club Car
1984 2008 Club Car Golf Cart Repair Manual Download
Sorry, I can't find a free 1987 version. The first link is a way to directly order from Club Car. No way for me to know for sure but you might take a look for similarities in the following: http://www.clubcar.com/content/dam/cc-corp/documents/pdf/pdf/ownersmanuals/DS-Manuals/1014409%201287B00000.pdf
Aug 10, 2017 | Golf
Club car golf cart only accelerates half speed
What year model? Should be the first numbers you see after the letters in the serial number.
Jun 02, 2017 | Golf
Governor on my golf, I would like to remove it.
Travis, Removing governor from your cart. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to remove governer on Club Car golf cart
How to Adjust an Go Golf Cart Governor
How to Take Governor off Club Car Gas Golf Cart
Aug 07, 2016 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Solenoid clicks. Why doesn't it go?
Need to know what kind of cart you have. Ezgo, Club Car?
36 volt, 48 volt ? for ezgo look at manuf. code, for club car serial number has the year. Then maybe we can figure out something.
Sep 09, 2015 | Golf
Find the year serial nimber A9649-548612 club car golf cart was manufactured
Since 1981 Club Car Golf Carts have positioned their serial numbers just under the glove box on the passengers side of the vehicle. The first two numbers (not letters) indicate the last two digits of the year of manufacture.
On Club Car Golf Carts prior to 1981, you can find the serial number by raising the seat and locating the aluminum, I-beam frame section closest to the batteries on the driver's side of the car. If the serial number plate has been removed, you can confirm it is a 1975-1980 model if it has two brake pedals and one accelerator pedal.
Oct 20, 2014 | Golf
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
Need a club car golf cart service manual
generic suggestion
Sep 30, 2008 | Computers & Internet
Golf Logo
379 people viewed this question
Top Golf Experts
ray gallant
Tom Chichester
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
