Question about Deadbolt Locks & Locksmithing
I recently changed the batteries on my Defiant Electronic Deadbolt and now it just emits loud beeps at random intervals. The batteries were brand new so I'm not sure why. Anyone know a solution?
Posted by Troy Miller on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: UPS Internetoff700 keeps wont stop Beeping
this is normal when especially when we have short flow of power,or power spikes,surges and sags.it is not overloaded at all i had such a problem some times back en ma technician told me it is ok
Posted on Feb 10, 2008
Anonymous
  • 9 Answers
SOURCE: I have a 907 Powerbolt Touchpad Electronic
Take the back off of the deadbolt where you install the batteries. The instructions are inside.
Posted on Jul 07, 2009
Dan
  • 14 Answers
SOURCE: random beeps
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
-=dån=-
Posted on Sep 14, 2009
CanBus
  • 14 Answers
SOURCE: Whenin use, my c80 emits a series of 3 loud beeps
You have triggered MOB (man over board) press and hold the MOB button in for 30 seconds.
Posted on Sep 23, 2009
Anonymous
  • 105 Answers
SOURCE: press start on the samsung front loader j845 and
De means door error and the door lock needs replacing. the part number is DC64-00519B if your model number ends with AAG
Posted on Feb 01, 2010
Defiant electronic deadbolt manual
I only saw manual mentioned on suspicious or malicious websites/
Sometimes manuals appear for sale on eBay.com or Amazon.com.
Home Depot could be contacted for a manual, as it is their brand name.
Searching for a youtube video might help you.
Example:
https://www.clipzui.com/video/u3q464q2u3z4p4m4162524.html
Electronic Deadbolt Door Lock Install Defiant clipzui com
Apr 21, 2018 | Locks & Locksmithing
Weiser lock began to emit a single long beep at regular intervals of several minutes. Changed the batteries and reset the code and it works fine, however, still continues to emit a single long beep at...
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page. Here you will find the appropriate contact numbers, US or Canada:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Aug 04, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
My touchpad electronic deadbolt has been working fine but now, when I enter the code, it beeps for each entry number and then emits a constant blast for 10 seconds and goes dead. I've changed the...
Powerbolt is beeping
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Oct 28, 2010 | Weiser Lock Powerbolt 1000 Lock
Changed the batteries but the Weiser keypad lock keeps beeping
Mine did that too for a month. Make sure all the batteries are new alkaline batteries of the same brand, and remove them for a few minutes (if already installed) and replace them in the unit. I reset my code as well afterword. Did the trick for me.
Aug 23, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
1) After unlocking door unit emits 2 beeps 4 times? 2) Green LED in door continually flashes?
remove all batteries, wait about 10 seconds then install new ones, one at a time, I found this clears the flashing
Mar 24, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Kwikset smart code touchpad electronic deadbolt
I have the same problem, electronic locking system went dead but still beeps, stuck using keys now...according to the kwikset website though it says "Warranties cover the original residential user of Kwikset Products against defects in material and workmanship as long as the original user occupies the residential premises upon which the product was originally installed." so hopefully they will fix the problem
Oct 12, 2008 | Deadbolt PFK Touchpad Electronic Lockset
Locks & Locksmithing Logo
997 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
Andrew Taylor
Andrew Taylor
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
