Question about Cutter Tools
I need safely separating 2 utility knife blades apart from one another.
Posted by Lindsay Schmid on
steve
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 35,301 Answers
Use a 3rd blade to separate them. use your head
Posted on Aug 16, 2018
5 Related Answers
Anonymous
SOURCE: I cannot open the front of the utility knife to
I was able to find the answer on another site. It is really simple when someone tells it to you. You push the blade all the way out then you can push the yellow button and it comes out.
Posted on Sep 07, 2009
ADRIAN
  • 313 Answers
SOURCE: How do you load a new blade?
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part, now slide the yellow part back to reviel the blade folder. Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
Posted on Jul 31, 2010
puertobori
  • 7733 Answers
SOURCE: Just purchased a Stanley fatMax
Some models has 2 screws on the knife case.unscrew them and you can access to the blade.
Posted on Nov 08, 2010
lstimo
  • 27 Answers
SOURCE: I cannot figure out how to put a blade in my
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
Posted on Apr 21, 2011
Jackie Parcus
SOURCE: stanley 10-788 how to change blade
Push the top metal button all the way foward as if pushing the blade out to it's (farthest) 3rd setting. Then push foward and down one more time which locks the mechanism down. Push and hold the yellow side button as you insert the blade. When the blade locks in all you have to do is release the yellow button and return the top slide to it is fully retracted home. The blade is loaded
Posted on Feb 04, 2012
I disassembled the Stanley 10 - 788 utility knife completely how do I put it back together
This utility knife reassemblies similar to the original. The only difference is this model uses two screws and that plastic insert. You will align the two metal halves and bring them together. Use care that the blade does not fall out of its holder and the little black plastic piece stays in place, near the blade. This may take a few tries. after you bring the two halves together you will carefully separate the bottom end (farthest from blade). Separate it just enough to slide the plastic insert into position. Once the three pieces align you will know. With little effort the two metal halves will close together. Install the two set screws and test for proper function. I'm including a Youtube video that shows how to properly change the blade and what it will look like after it is reassembled.
https://www.youtube.com/watch?v=5napTSRSyeQ
Sep 23, 2018 | Cutter Tools
How to change the blade on a new model Kobalt fixed blade utility knife
It literally splits in half. Find the tabs to pull it apart- and you may find spares in the base
I’m happy to assist further over the phone at https://www.6ya.com/expert/josh_8f8ad0a8f7e0e6d3
Jun 04, 2014 | Cutter Tools
How do I change the blades in a Benchmark Utility Knife that has a rubber grip and there is no screw to get it apart.
The knife does not come apart. Push the top button (blade) all the way forward and keep pushing forward now press the side button . Being careful with sharp blade pull the blade forward gently. It may need to wiggle a bit but it will come out. Insert new blade while pressing side button. goodluck
May 04, 2013 | Tools & Hardware - Others
How do i replace the blade on my utility knife?
loosen the screw that is holding the two casing halves together and separate the halves. pay attention to which way the old blade is in the compartment, remove it and put in a new blade in the same direction. close the casing and tighten the screw
Jan 16, 2013 | Cutter Tools
I can not get the blade out of my dewalt retractable utility knife dwht10046
Just take apart the knife and get knife out reassemble it and then put the knife back in
Nov 23, 2012 | Dewalt Tools & Hardware - Others
I have a stanley 99e. i took it apart ti change the blade, without paying attention, and now i can't re-assanble it properly. I can't find any instructions online.
Hi.
See here the Stanley knife disassembly. If you have a 99E there may be an additional plastic part that is not shown in the diagram. The plastic tab is located at the back of the blade.
Jun 02, 2011 | Stanley Utility Knife
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Cutter Tools Logo
428 people viewed this question
Top Cutter Tools Experts
efs_perpends
efs_perpends
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Cutter Tool Expert? Answer questions, earn points and help others
