Check if the base power adapter is warm to the touch. If it's cold, then the base has no power. Test if distance between the handsets and the base is an issue by moving closer to the base. Check for any radio interference. Check if the handsets are registered. You may need to de-register them first. Try unplugging the base (power and phone line cord) then remove the batteries from each handset. Wait at least 15 minutes before restoring the power/batteries. If the base has a charging cradle, place one handset in that cradle and wait a few minutes. See if that handset works. Otherwise, try to register one of the handsets and see if it works.
If the problem persists, then the base probably has a problem transmitting or receiving the signals from the handsets. Unless the system is under warranty (one year), you should replace the system. Otherwise, contact Uniden customer support.
I hope this helps. Please add a comment with the model of the Uniden phone if you want directions for registering/de-registering the handsets.
SOURCE: Request help to retrieve message,then turn off answering function
You might try going to unidendirect.com, scroll down to "customer service" and click there. a FAQ list comes up. #8 is remote access messages, maybe your other issue would be answered as well.
SOURCE: Canon imageCLASS® MF4150 All-In-One picks up all calls on our second line.
I got in touch with the manufacturer tech support and found there was no way around it. Thanks for considering my issue though :)
SOURCE: Uniden PowerMax5.8 GHz
Yes, it will automatically let you know when you have a voicemail. If it does not work, contact Comcast.
SOURCE: "i have a uniden 6 0 dect2080 3 answering machine how to check the messages from a different phone"
The default security code is "80". If you have not reset that code, you will use 80.
This is all from the manual:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about ten rings and sounds a series of beeps.
2) During the greeting or the beeps (if answering system is off), press 0 (zero) and enter your security code within 2 seconds.
3) The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero" followed by a beep.
Then the manual lists all the remote commands. If you need those, you can go to uniden.com and download a manual.
