SOURCE: How do you set the TV code for the remote:
How to Program the RMT-B107A Remote Control:
Follow these steps to program the remote control to operate a television.
1) Turn on the TV.
2) On the remote control, press and hold the TV I/O button.
3) While holding the TV I/O button, enter the manufacturer's code using the numeric buttons.
NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
4) Release the TV I/O button.
5) Point the remote control at the TV.
6) Press the TV I/O button to verify operation.
NOTES:
If a new code number is entered, the code number previously entered will be erased.
When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
The operation of a combination deck of any kind is not guaranteed.
Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
SOURCE: what is the tv code for olevia brand tv for sony
I'm not sure there is a code for the b107a. (There wasn't on my old Sony remote either.) I just bought a Sony RM-VLZ620 for about $20 and it does have codes for Olevia.
SOURCE: what is the code to
Hello
Setup codes for Sylvania Tv with Sony RM VZ320 remote control are:
00054/00171/01271/ 01314/01394/01864/01886
OK.
SOURCE: I want to program my
I know that it has been a while since this question was originally asked, but I figured that I would share what worked for me.
Here is what worked for me: (RMT-B107A remote and Vizio TV)
1. With the TV on, Press and hold TV I/O button
2. Press 04 on the number keypad.
3. Press the TV I/O button and the TV should turn off
This method also allows me to control the volume on my Vizio. The TV input button did not work.
SOURCE: can a sony rmt-b107a control a citizen television
Check these codes. 035,024,071,083. If you cant synchronize these codes, try some other setup codes to Citizen brand TVs. If you wish to get more codes, check this link. There is setup code list to different other brands of remote controls. Never stick on Sony brand remote itself. Only mind the brand name to your TV; not the remote control.
