Question about Furniture
I just received a new remote for my tempur pedic bed how do I set it together
Posted by Vonda Owens on
3 Related Answers
guyyouknow
SOURCE: tempur-pedic remote control does not
If the solution posted by Susan R. (below) fails to work, locate the black power down box under the bed. Check the battery compartment and remove all batteries. If batteries are installed they will prevent a full reset of the box. Unplug the power cord, wait 45 seconds and plug the power cord back in to reset the electronic components. Replace batteries. Now that the error has been wiped from the box's memory, you can now synchronize your remote with the power down box using Susan's instructions below. - Mike V., Antioch, CA
"Locate the power down box for the bed and press the "learn button" for 1 second and release (Black box under the bed). On the hand control, simultaneously press and hold the position 1 and off buttons. The transmission indicator light will flash slowly and then flash rapidly. Continue to hold for 5 seconds and then release the buttons. It should now work! Enjoy. Susan R., Paducah, KY"
For further assistance, refer to the user manual that came with your TEMPUR® Advanced Ergo System™ or you can download it here.
http://www.tempurpedic.com/media/Ergo_System_Complete_Ref_Guide_FINAL_022008.pdf
For phone assistance please contact a Leggett and Platt representative at 800-888-3078. Leggett and Platt is the manufacturer of the adjustable bed and remote components for Tempurpedic.
Posted on May 18, 2009
AndrexT
Andrew Taylor
  • 34051 Answers
SOURCE: I need to replace my Tempur-pedic remote controll
Direct from the company
https://www.tempurpedic.com/other-products/s/tempur-ergo-accessories
Posted on Jul 13, 2018
AndrexT
Andrew Taylor
  • 34051 Answers
SOURCE: tempur pedic bed remote control
Oh yes we are, but sometimes it takes a few minutes! You posted to the category 'Cars and Trucks', which doesn't help.
$100 direct from the company.
Tempur Pedic Products Accessories
Tempur pedic bed remote control
Jul 13, 2018 | Cars & Trucks
How do I lower the back?
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
(This definitely applies to Tempur-Pedic TP4100 Office chair.)
Nov 01, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
How do I lower the back of my chair
Sep 09, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
How to adjust the back of the chair?
To lower the back, <b>lift</b> it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
Jul 01, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
The bed is stuck with head up can I manually lower the bed
We have a Tempur-pedic. Each side is controlled by its own remote. It also has battery backup for each side (head and foot) in case the power goes out. We simply push a little button on the battery controlled box on whichever side needs lowered. It works to lower them, but they cannot be raised in a power outage. If you don't have something like that, or a manual crank or something, I suggest you call the company and ask THEM what to do. If it's stuck with the power still on, then even more reason to call the company.
Apr 23, 2014 | Ergomotion Furniture
What is the difference between Tempur-pedic mattresses and other brands of memory foam mattresses?
Tempur-pedic is a type of memory foam. They are a brand name distributer of memory foam products. They have reached a level of popularity now, which consumers refer to their product as a brand (similar to Kleenex).
Jul 25, 2012 | Furniture
Furniture Logo
261 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
