SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
SOURCE: Hi We are setting up our
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
SOURCE: I HAVE AN ONKYO TX
The symptom you described can be caused by any number of things. I always start with the output power transistors which are the first things to blow with a speaker output overload condition. Unplug the power cord to your unit, remove the top cover and use an ohmmeter to check resistance from C to E on all 10 of the power transistors (Q6050 thru 54 and Q6060 thru 64) attached to the large heat sink. Blown transistors typically read <1 ohm, compared to good transistors that are >10k ohms. If you find a bad transistor it will need to be replaced.
SOURCE: Rear surround speakers quit working from my Onkyo
It looks like the audio output was changed on the player so that it doesn't output 5.1. Enter the setup menu on the player and change DTS to output DTS instead of what be labled as stereo or L/R and Dolby Digital to output Dolby Digital instead of whatever else it is set to.
