Question about Dirt Devil Vacuums
Turn on the dirt devil easy lite cyclonic and sounds like it's working, but the belt won't move. gets real hot. motor drive? fuse? can i fix and how please
Posted by Elori Mercifell on
Thatvacguy.com
  • Dirt Devil Master
  • 1,604 Answers
Make sure the brush roll will spin freely, if so install a new belt.
Posted on Aug 15, 2018
5 Related Answers
reddevil6
Lauren Junge
  • 1673 Answers
SOURCE: Dirt Devil vacuum
You might unhook the belt, if it still sounds real loud, then the motor is bad and will have to replaced.
Posted on Jan 06, 2008
ukvacfan
Ryan S
  • 328 Answers
SOURCE: Dirt Devil Reaction Dual Cyclonic- M110000, "cyclones" not spinni
If the filters have been washed and installed back in instantly there wont be any suction. Check the top filters have been cleaned thoroughly and also check inspection tubes/hose and dust channels to check for a clog. Also check the sole plate / bottom of where the beater bar as there may be a clog somewhere.
Posted on Jan 23, 2009
Anonymous
  • 76 Answers
SOURCE: Belt keeps breaking on dirt devil 85335
check and see if the brushroll still turns easy. if it doesnt, u may need a new brushroll which can be found on ebay, or dirt devil's website
Posted on Aug 22, 2009
Anonymous
  • 18 Answers
SOURCE: Dirt Devil Repair
You can use eReplacementParts.com for the detailed diagram or exploded view of that vacuum. You will also find a full parts list, and possibly repair videos to help you out. - Dirt Devil Parts and Diagrams
Posted on Jun 02, 2010
Steve Butterworth
  • 938 Answers
SOURCE: Dirt devil turbo clean sd40060 Cyclonic vacuum. Was given it as a present. Floor tool won't spin. Checked everything! Belt, for hair through out. All ok. Why isn't it working?
You should find a large button or flap on the floor tool. This is usually spring loaded and needs to be OUT. This should then let air in to drive the turbine which drives the spinner.
Check out Vacuum Cleaners Upright Hand Stick Canister Vacuums Dirt Devil
Posted on Aug 08, 2015
Aug 08, 2015 | Dirt Devil Vacuums
Dirt Devil easy lite vacuum makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi there! Sounds like that noise may have been your belt popping or breaking. Try checking the belt on the vacuum. If it has broken, replace with a Dirt Devil style 15 belt. Below is a link where you may go to purchase the belt if needed. Thanks!
Style 15 Belt 2 Pack
Apr 28, 2014 | Dirt Devil Easy Lite Quick Vacuum
Dirt Devil easy lite makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi, it's Cindy from Crucial Vacuum.
From your description, it sounds like there may be something stuck in your roller or your filter may need cleaning or replacement. Refer to page 22 of your manual to remove your roller.
For optimal performance, your filter should be replaced every 3-6 months and washed every 1 month. Your filter is located under the dirt cup holder.
You can purchase direct your replacement filter from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f43-easy-lite-cyclonic-hepa-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Bush roller squelling on dirt devil 130005 upright bagless cyclonic vacum
My dirt devil has 3 screws underneath- these are the same ones you use to change the belt--sounds like something is caught in roller-- mone was full of hair!
Jan 02, 2014 | Dirt Devil M130000 ''i'' Dual Cyclonic...
No clogs, work fine, but makes a very loud wailing sound? what could it be?
My Dirt devil Reaction does the same thing. So I took apart the motor and it was crammed w/ dirt then I decided to clean it out. next time I vacuumed my house it was a lot quieter. The guy from Jones sew and vac said baggless vacuum filters most of the time fail and let dirt get in the motor and start to scream. I read a lot of things saying Dirt devil Reaction is the most common vacuum to get dirt in the motor and start to wail then get worse & worse and get to the point where they start to almost scream. P.S if you let it scream for along time of use it will give the motor permanent damage and you will smell electrical burning, if that happens it will be too late so you will half to buy a new machine. To get to the motor you can take the dust contaner off and take the black filter then use your down stairs vacuum and get a small attachament and stick it in and vacuum it out,if not have two vacuums borrow one. If that doesn't clean it out you will need to take all the plastic appart and realy get to the motor good. If my advice dosn't help it is ok to still use it, it will just be loud until the motor of it is totally fried. This should work it worked on my Dirt devil Reaction. I'm sorry if it doesn't work out. :D
Apr 17, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
I cant get the power brush to work is there a reset button? the vacuum is only 2 months old dirt devil 12amp bagless featherlite
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Apr 06, 2009 | Dirt Devil M085850 Featherlite Bagless...
Jan 15, 2009 | Dirt Devil M110000 Bagless Upright...
Nov 23, 2008 | Dirt Devil M085580 Featherlite Plus...
Dirt Devil vacuum
Jul 29, 2007 | Windsor SR12 Sensor Bagged Upright Vacuum
Vacuums Logo
Top Dirt Devil Vacuums Experts
Tim Venetis
Randy Schumann
Randy Schumann
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
