Question about Whirlpool Microwave Ovens
Change lightbulb in Whirlpool microwave oven VT251
Posted by Penny Peberdy on
5 Related Answers
Anonymous
SOURCE: Changing oven light
I have a light bulb in my oven that is frozen, won't come out. The whole unit turns when trying to remove it. Any suggestions?
Posted on Sep 17, 2007
Anonymous
  • 184 Answers
SOURCE: Replacing lightbulb in Sharp R953M combi microwave oven
most microwave ovens built in the last 20 years do not have an
access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
Then pull upward and backward on the sleeve to disengage it
from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
are not unscrewable from the socket, but the socket and bulb
come as an assembly.
Posted on Mar 27, 2008
THENTHEREWER
Terry Rodgers Jr.
  • 131 Answers
SOURCE: How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Posted on Nov 08, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: HOW TO CHANGE VIKING MICROWAVE LIGHTBULB VMOS200
The Viking VMOS200 is essentially a rebranded Sharp R-530E.
One or both of these service manuals should cover disassembly and location of the bulb:
http://www.microwavedisplay.com/r530ekt_r530est_r530ewt_sm.pdf
http://www.microwavedisplay.com/r530es_sm.pdf
Posted on May 30, 2010
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: How do I change the
On this model, you have to remove the outer cover of the oven, then you'll find the lamp in the socket mounted on the air duct above the magnetron on the right side of the oven.
The DMO24S is essentially a rebranded Sharp model R-530E, so its service manual (here) will tell you how to disassemble it, but the proper part numbers are found in the DMO24 parts list here.
You can find links to helpful exploded view diagrams and part ordering help here.
At that last link, when looking for Dacor parts, you have to search by part number only.
I recommend that you bookmark that link to your favorites.
Posted on Jan 02, 2011
Wrn52hwg6 fridge
Just try. If there is a plastic protector pull it off then change the bulb
Oct 20, 2013 | Whirlpool Microwave Ovens
Tip
I can not believe I have to jump through these hoops just to change a feaken...
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at [email protected]
Craig Pays
Kenner, La.
on Aug 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The lightbulb cover on my whirlpool WFE361LVS wont unscrew, how do I get it off, I need to change the bulb
Most microwave ovens lamps' outlast the life of the microwave. So, most of them do not have access covers for the oven lamp. The lamp has to be replaced from inside the unit. Also, the newer units tend to use bulb assemblies rather than just a screw in type bulb. Call Whirlpools 800 help line or your local appliance parts store and have them look it up for you.
Sep 19, 2013 | Microwave Ovens
Change lightbulb
most times you have to take the outer case off (the stainless steel part) and then you can see all the wires circuitry etc. thats how you get to the light bulb. make sure you unplug the microwave first and do not touch where it says electric shock hazard it will shock you even if not plugged in
Jul 16, 2012 | GE JES1142SJ Microwave Oven
How to change Lightbulb in oven
unscrew the old one than screw in the new one...
Jun 25, 2011 | Whirlpool Microwave Ovens
The lightbulb in my Whirlpool Gold Microwave & Convection oven has gone out. How do I change it?
On this model, the lamp is mounted in the air duct near the magnetron inside the oven and is not considered user accessible.
Some manufacturers still include access panels so you can easily change the bulb. Those expose the customer to 110V connectors, and that poses a real liability threat, so many stopped using them.
So you must remove the outer cover to replace the bulb.
See these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 07, 2011 | Whirlpool GM8155XJ Convection/Microwave...
May 28, 2010 | Viking VMOR205SS Microwave Oven
How do I change the lightbulb?
4359741 You have to remove the outer case and it will be accessible. Eric
Aug 02, 2009 | Whirlpool GT4185SK Microwave Oven
Nov 08, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Sheldon Dedek
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
