Check all your power connection if that does not work check fuse at back of radio may be blown
Posted on Jul 11, 2019
SOURCE: JVC KD-G431 IN CAR CD PLAYER "000ZAAA" Error
I had the same problem. It started when I tried to play an MP3 track from a "Creative Zen Vision M" Media Player. The result was the same as you describe = Maddening. It was extremely annoying that the CD player did not work. I thought I had broken the equipment.
Then my wife read the product hand book , and noticed on page 2 http://jvcmobile.co.uk/documents/products/KD-G431%20Instructions.pdf it showed, where using a pen you can reset the equipment back to the original settings. I thought I might as well give a try. It worked = Fixed. Amazing. I was so relieved. Such an easy solution.
Give it a go. I reckon there is a good chance it will fix your problem, and you will also be very relieved. Just use a basic MP3 player in future. GOOD LUCK !!!
Posted on Mar 22, 2008
SOURCE: Setting the clock on JVC KD-G230
Check out this pdf http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
Posted on Jun 10, 2009
SOURCE: how do I set the time
Press the "SEL" key for more than 2 sec. Turn the volume to set HH for hour and MM for MM by +/- button.
Posted on Jun 13, 2009
SOURCE: how do you set the clock on a jvc kd-g230 car
There is a misprint on manual concerning setting the clock. This is the case for similar JVC mobile head units.
The proper way to set the clock for this unit is:
1.)Hold down 'SEL' button count to 3 seconds
2.)Immediately after release of 'SEL' button hit the '>>|' button
This will allow you to enter 'PSM' menu. Every time you press '>>|' it will cycle between, 'CLOCK HOUR','CLOCK MINUTE', and 'Demo' Mode.
3.)Adjust settings by using the 'turn knob' and make sure 'Demo' mode is set to 'Demo Off' for the clock to stay set.
Posted on Nov 17, 2009
SOURCE: Car radio connections
Red wire to acc fuse
yellow= b+ fuse
blue= to amp amplifier
white= +left front speaker
white/black left front - front speaker
gray= + front right
gray/black= - front right
green= + rear left
green/black= - rear left
purple= + rear right
purple/black= - rear right
black = ground---to car metal
orange with white line to illimination
Posted on Apr 28, 2010
Jun 05, 2015 | JVC Kd-R331 Cd Car Stereo With Front Aux...
Aug 04, 2014 | JVC Car Audio & Video
Mar 17, 2010 | JVC KD-G140 Car CD Player
Feb 10, 2010 | JVC KD-S6060 CD Player
Feb 06, 2010 | JVC KD-LH910 CD Player
Aug 09, 2009 | JVC KD-AVX11 Car DVD Player
May 25, 2009 | JVC Car Audio & Video
Dec 10, 2007 | JVC KD-G820 CD Player
Nov 07, 2007 | Car Audio & Video
201 people viewed this question
