Question about Maytag Refrigerators
Maytag Refrigerator compressor clicks - Maytag Refrigerators
Posted by Vickie Gonzales on
david thompson
    Habit-Forming:
    New Friend:
  • 6 Answers
You might have a bad start capacitor,try a 3 in 1 compressor relay
Posted on Aug 19, 2018
5 Related Answers
Anonymous
  • 290 Answers
SOURCE: Maytag msd2454gr
The click is not normal. The compressor is not starting and is tripping the overload. There is a chance the start relay on the compressor is shorted, but most likely the compressor will have to be replaced.
Unplug it for several hours until the compressor cools down and then try it again, if it starts up ok when it is cool the compressor is the problem for sure.
If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge.
Posted on Dec 07, 2007
David Coomer
  • 1073 Answers
SOURCE: Maytag refrigerator 6 years old
either the compressor or the compressor relay is bad, need amp meter to check amp draw on compressor to verify problem
Posted on May 17, 2008
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: Maytag refrigerator isn't cooling
Hi ****, Based on the discription you've provided it sounds like either a faulty start relay or the compressor is seized. If you have a multi- meter you can check the compressor to see if the windings are ok. Unplug the fridge. Remove the panel at the back down at the bottom. This should gain you access to the compressor. On the side of the comp. will be the start relay/overload assembly. Pull off the relay & overload and you'll see 3 pins in the form of a triangle. With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin. You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms. On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good ! If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit. This will start it if it's not seized also known as a "locked rotor".. You can find them at most brick & mortar appliance parts locations or on-line vendors. The package contains info on how to connect it. If that doesn't yield any results moving forward, let me know we'll go from there. **I suggest you phone Whirlpool customer support first though ( they own Maytag ) as they recently had a massive recall regarding the starting device of many compressor's and you may find your's to be included therefore have it repaired at no cost.** they will know by your model and serial number or if that isn't clear the number on the compressor. Good Luck Thanks for visiting "fixya", please take a second to rate my solution and leave a comment/testimony to it's helpfulness. macmarkus :)
Posted on May 02, 2010
aasc
Mike Smith
  • 1606 Answers
SOURCE: Maytag refrigerator compressor dosen't operate
Did you wire the 3 wires on the overload / relay correctly ?
Posted on May 25, 2010
danny Hendrickson
  • 2468 Answers
SOURCE: maytag refrigerator MTB2156GE compressor is
replace the ptc overload relay on the compressor with an exact replacement and all will be well no more clicking and good cooling again
Posted on Mar 07, 2011
I have a Maytag MZD2766GES refrigerator and it stop cooling. It has a continuous click sound near the compressor like a relay device. I changed the running capacitor and the click sound every 2 1/2 minutes...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 24, 2011 | Maytag MZD2766GES Side by Side...
The Maytag refrigerator Serial # 50124981GT, Model MTF2191AR is not cooling or freezing. Moisture is forming in the freezing unit and the cooling area is getting warmer. I was told this could be a...
Refrigerator
heatman101
Jan 28, 2011 | Maytag MTF2191AR Top Freezer Refrigerator
I have a Maytag side by side refrigerator(PSD243LGRW), the compressor dosen't work, no cooling at all, even the fan is running. After I change a overload/relay, I can hear ''click'' sound every few...
You can try the capacitor and relay first, but you may have a fried compressor...the click is the compressor trying to start...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
May 24, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag MZD2766GES refrigerator quit cooling, both sides. Noticed frosting on freezer contents, and next day the ice maker ice was melting and running on the floor. We can hear a clicking every 5-10 minutes...
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Remove the cardboard backing from the back bottom to access the compressor area.
Dec 20, 2009 | Maytag MZD2766GES Side by Side...
Maytag MSD2756GE Side by Side Fridge
You have a bad compressor, time for a new refrigerator. Check your warantee for compressor failure. Might be 5 years.
Dec 31, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator not cooling
the clicking noise is probably the compressor srart relay opoerating but the compressor not starting. compressor faulty and an expensive repair
Sep 03, 2008 | Maytag MBB1956GES Bottom Freezer...
Maytag refrigerator clicking
it sounds like a bad:
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 06, 2008 | Maytag 23 cu. ft. Side-by-Side...
Maytag msd2454gr
Dec 07, 2007 | Maytag MSD2456G Side by Side Refrigerator
Refrigerators Logo
162 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
