Question about Compaq Computers & Internet
Need charger for Compaq Presario 1200XL600 laptop
Posted by Jay Darby on
Larry Ng
  • Compaq Master
  • 5,966 Answers
The AC power packs are at ebay too.
if you google it , it like a zillion hits.
try google or ebay or amazon.
Posted on Aug 14, 2018
Terry
  • Compaq Master
  • 11,124 Answers
Tom Chichester
    Top Expert:
  • Compaq Master
  • 55,379 Answers
Fixya does not sell chargers for Compaq Presario 1200XL600 laptops.
Posted on Aug 13, 2018
Testimonial: "Didnt ask who sold them ?"
5 Related Answers
Anonymous
SOURCE: compaq presario c700 laptop
ALL THE DRIVERS U'LL EVER NEED FOR COMPAQ PRESARIO C700
(VGA) Driver:
http://downloadmirror.intel.com/13300/a08/win2k_xp1429.exe
Chipset Driver:
http://downloadmirror.intel.com/13499/a08/infinst_autol.exe
Wireless LAN Driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34152.exe
ALPS Touchpad Pointing Device Driver:
ftp://ftp.hp.com/pub/softpaq/sp31001-31500/sp31075.exe
5 in 1 card reader driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33604.exe
HP Quick Launch Buttons
ftp://ftp.hp.com/pub/softlib/software8/COL18360/ch-47422-1/sp33258.exe
LAN Driver
ftp://ftp.hp.com/pub/softpaq/sp30501-31000/sp30580.exe
To install audio / modem drivers, first download and install Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (sp32646):
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Conexant CX20549-12 Audio Driver for Microsoft Windows XP (sp36090.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
This will create a swsetup folder in C drive ("C:\sp36090")
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\sp36090 folder and select the .inf file (CpV30D5a) and click open and Continue with the onscreen instructions.
Conexant CX20548 Modem Driver for Microsoft Windows XP (sp36089.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
Download and install Conexant modem driver (sp36089). This will give error message and also will create a folder C:\swsetup\sp36089 which contains extracted driver files.
The same method which is used for installing audio driver needs to be followed for modem.
Posted on Feb 24, 2008
myob247
Georgia B
  • 1342 Answers
Use this link to find your specific model of the Presario c700
Posted on Apr 05, 2008
Anonymous
  • 4 Answers
SOURCE: need audio driver of compaq presario V6000
usually all drivers for Compaq and HP computer systems (portable and non-portable) can be found on the HP support website (Click here to go to it), simply go there, chose your region, than your country, enter your model number (not the series, the model number, you would usually find it on the service tag, or wherever you would find a serial number), but be sure to chose "Download drivers and software (and firmware)", and than chose your operating system. Hope this has helped.
Posted on Jul 06, 2008
Anonymous
SOURCE: I need audio drivers for compaq Presario F500 laptop
 helo ser i'm joni rahman . from indonesia  plis whit deriver vga,sound,wireles, driver to all fromPresario 500 laptop
oke thengs ser
Posted on Nov 17, 2008
Anonymous
  • 10 Answers
SOURCE: compaq presario m2000 sound card
Hi Friends,
Compaq Presario PC Notebook's main problem's are Audio Driver, Software Installation etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here .
Posted on Jul 22, 2010
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
I have bought a new charger for my laptop, compaq presario cq56, and it is still not charging
Other expert is right--if not charger may be a loose socket where it plugs in or even a bad battery is possible.
Jun 12, 2012 | Compaq Presario CQ56-115DX Laptop
I want to buy charger for cq50-110us
Hello
Although we don't sell parts as a courtesy I have looked up a site for you that carries this charger at a reasonable price. Please follow the link below to the site to purchase the charger.
http://www.laptop-power.com/laptop-adapters/Compaq/Presario/CQ/CQ50-110US.html?gclid=CMj29_KhgaoCFakaQgodPkgM0w
Jul 14, 2011 | Compaq Presario CQ50110US Laptop Charger...
I need this charger
hi calvinis, you can go to Ebay.com or amazon.com to buy your compaq persario charger, in ebay you have more security in purchasing any product , and you have shipping to any part of world , before searching in ebay , check whether ebay have seperate domain for your country , so that shiping will not take more thn one week to reach you. i have already search one product for you
http://cgi.ebay.com/COMPAQ-Presario-CQ40-CQ45-CQ50-CQ60-AC-ADAPTER-Charger-/250558120799?pt=Laptop_Adapters_Chargers&hash=item3a566d835f
copy and paste about link in browser.
Good luck
Jan 12, 2011 | Compaq Battery Charger Adapter Cord For...
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Presario v2000 charger burning
first you check yo charger and also your battery. make sure to check if the battery is ok and buy the charger of the same kina as the original one. if problem still occur then change the battery.
Oct 27, 2009 | HP Compaq Presario V2000 Notebook
My Compaq Presario CQ60 charger will not charge
try diffrent charger or try to turn on ur laptop with out the battery might be a problem with charger or battery
Aug 16, 2009 | HP Compaq Presario CQ60-249US Notebook
Compaq presario v2000 heating problem
nothing is wrong with ypur laptopmotherboard. i suggest you to use original charger. doublicate charger are not good for laptops .
Aug 04, 2009 | Compaq 389897-001 - HP/ Presario V2000...
Computers & Internet Logo
88 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
