Question about Compaq Computers & Internet
I need charger for this Compaq laptop - Compaq Computers & Internet
Posted by Jay Darby on
Thomas Smouse
    Scholar:
    New Friend:
  • 81 Answers
WE ALWAYS RECOMMEND THE ORIGINAL OEM PARTS.
The original charger will cost you an arm and a leg and just maybe a toe from the leg you will have left
Go cheap and buy Universal Laptop charger at any electronic shop.
The Universal charger comes with various adaptable heads that fits into most laptops charging pins. This can tie u over until you can afford the original.
Posted on Aug 14, 2018
  • Anonymous Aug 27, 2018
    bah
    ebay has them.
    but sure all OEM parts of anything cost more.
    cars, computers and more.., yadah yadha.
    you can find used AC/DC power packs, for any HP. or compaq there. or new.
    but do not use universal packs, ever.!
    and get the voltage and wattage correct.
    best is 65watts up.
    OP you never once stated a real PC model
    if you had Id have shown you good ones to buy cheap that match,
    so nada from me.
    COMPAQ goes back to 1984, my guess yours not that old, am i right?
    2001 became HP.
    2013 compaq logo ended. 34 years of PC
    and 1000s of models.
    learn to that the watts can go higher.
    like what Gaming Laptops need,
    or it fails.
    Many power packs also have reset pin.
    that warns the PC that power is about to fail.
    Line AC power, (3 wires plugs into PC)
    there is and even chance HP does not sell your power pack at all so there is no true OEM pack
    ok. unless 2013 made.
    not the old models .
    again no PC stated, only LOGO "compaq"
    the hp parts surfer is clear on that.
    http://partsurfer.hp.com/search.aspx
    first tell country, yah, AC power not same outside USA.
    then [email protected]#
john h
    Top Expert:
  • Compaq Master
  • 23,401 Answers
Go to electrinis selling store or online search using make and model
Larry Ng
  • Compaq Master
  • 5,968 Answers
No pc stated
1985 to 2013 , compaq Trade marked.
they sell them on ebay cheap.
for all PCs made.
Need charger for Compaq Presario 1200XL600 laptop
Fixya does not sell chargers for Compaq Presario 1200XL600 laptops.
Aug 13, 2018 | Compaq Computers & Internet
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
I have bought a new charger for my laptop, compaq presario cq56, and it is still not charging
Other expert is right--if not charger may be a loose socket where it plugs in or even a bad battery is possible.
Jun 12, 2012 | Compaq Presario CQ56-115DX Laptop
My laptop compaq cq40 is not charging, i think there is a problem on the charger
I would recommend taking it to a battery retail store or laptop specialists to have the charger and battery tested. It can be very expensive to purchase either a battery or a charger or both if not needed. Have it tested to verify the problem device ....then purchase as needed.
May 27, 2011 | Compaq Presario CQ40 Series Laptop Charger...
When i insert the charges plugged in laptop mouse is not working properly.
Hi Raviseetha,
This is the issue with the Laptop Charger, your charger is faulty.
I would recommend borrowing a friend or family's laptop charger that works on your laptop and see if it works. If it does not, then the problem could be something internal circuitary and you should ask Compaq to fix it. If it charger works, then the problem is definitely the charger, possibly because it is not providing enough power which would usually happens all the time with most of the laptops
If you laptop is under warranty,I am pretty sure if you ask Compaq to replace the parts or fix them if necessary. Else you could buy a new charger and it would fix your issue..
This should solve your issue.
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this solution.
Thanks For using FixYa!
Vinod Kumar J
Nov 28, 2010 | Compaq Computers & Internet
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Fuse keeps blowing on compaq charger why
I would say the best thing to do is purchase a new charger.
Follow this link: http://www.amazon.co.uk/s/?ie=UTF8&keywords=compaq+chargers&tag=googhydr-21&index=aps&hvadid=3125533376&ref=pd_sl_8cgbcig4rd_e
Feb 06, 2010 | Computers & Internet
Compaq presario v2000 heating problem
nothing is wrong with ypur laptopmotherboard. i suggest you to use original charger. doublicate charger are not good for laptops .
Aug 04, 2009 | Compaq 389897-001 - HP/ Presario V2000...
Does a laptop charger need a voltage regulator?
No. Your charger is designed to correct for input fluctuations and has a certain tolerances to meet for output voltage and current ripple.
Jun 17, 2009 | Compaq Computers & Internet
Computers & Internet Logo
108 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
