SOURCE: Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
SOURCE: panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
SOURCE: How to fix F61 error?
First re solder any dry joints on Transistors Q502, 504, 507, 515 & CN500, IC501. If there are no dry joins replace IC501 (STK470-0??) & maybe D501 (16.V) zener
