Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Convergance circuit board
How and where do you get a convergence circuit board for an RCA P52927yx2(service #)model # P5227..... chassis # ptk 195m2b..... serial #047441734.
someone please help.....got the 52" projection screen t v fromfamily menber for free....is it worth getting fix???????
I have the same convergence problem with my t.v, and I was told it would cost $500 to fix so If I could find out how to get the circuit board I would really like to fix myself!
KP-53HS30 HOW CAN I BUY A NEW CONVERGANCE FOR THIS TV?
Jose Zetino
  • 149 Answers
You don't need a convergence board the one you have could be fix the only problem is the alignment is not that easy and won't cost $ 500 unless you live in alaska and worth fixing it today you just get bad set made in chi???
Posted on Apr 05, 2008
Convergence problem can't be fixed with remote
Model indicated usually NEVER has convergence problems.
Look on back for "chassis" number, is it a PTK 195 chassis?
If it is I can tell you what is likely wrong and it is a do it yourself repair.
BEFORE YOU RATE THIS SOLUTION LET ME KNOW IF 195 CHASSIS.
SD TECH
Jul 27, 2011 | RCA P52937 52" Rear Projection Television
Where is the convergence power supply located on a RCA P52960?
TAKE A CLOSE LOOK AT THE LABEL ON THE BACK OF THE SET WITH THE MODEL NUMBER, IS IT MARKED PTK195?
THE PTK 195 uses a power supply mounted above the main boards and is about 10 inches wide and 4 inches deep.
It is very common on this model for one of the ten diodes to be shorted; confirm it is a 195 chassis and I will tell you how to locate the two diodes that fail. They supply voltage to the convergence circuit and I have seen dozens where one of them shorts.
Let me know what you find; is it a 195 chassis?
If this information has helped you rate this solution as I do this here for free, rate it "very helpful".
If it is a 195 chassis let me know and I will pinpoint the location of the two diodes and tell you how to check them.
REGARDS, SD TECH
Aug 10, 2010 | RCA P52960 52" Rear Projection Television
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
I located the board at PTS Electronics. Mine was the digital convergence board.
A little pricey but did the trick. Recommend that if you do not know how to drain off the capacitors. Let theTV sit unplugged for 3 to 5 days to drain them down below a possible fatal shock level.
Recommend taking good digital photos for your reinstall if you have no schematics or real electronic experience. Priceless advise !!
Do not touch any settings to try and adjust without knowing the original factory settings. It will get expensive to have a tech readjust. Lots of time to adjust and the tech knows you were there. $$$$
Jul 04, 2008 | Televison & Video
Convergence power supply board
try www.partsstore.com they should have the board you need if its still available from RCA
May 25, 2008 | RCA TH1101 MP3 Player
RCA P56926 Would not turn off
This tv make a lot loose connections. If you re solder and nothing change, check fly back area's is OK?... Look around convergence board for liquid coolant ( some times CTR liquid coolant projection splitter , becarfull, Liquid is danger!!) Wash yous hands and clean chassis with acetone.
Apr 19, 2008 | RCA P52926 52" Rear Projection Television
you dont need a new board just replace convergence ics that would be the way to go will cost you under 75.00 if you do it your self if you take it in it will cost you 250-350 depending on the shop
Nov 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence PCB probably not available....can you get me any #'s off the PCB or part # of STK IC or location # of convergence IC ??? ..................Should be worth fixing if I can get alittle more info....................T.
Note to mountain mom: You have a completely different
symptom ..............+ need service #.............
Try DVD ? all inputs ? cable box ? source to RF coax= on ch.3 ?..............................T.
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
RCA 52" Rear Projection P52930BL
You can adj. from the front panel of the set using the channel and vol. buttons,if the set you have has a ptk 195 chassis,check and make sure you have adj. projection tv in screens of the menu,in not the convergence power supply has failed,replace the reg on the board,part number is 215530
Oct 04, 2007 | RCA P52930BL 52" Rear Projection...
Misconvergence
Convergence on RCA P56940 chassis PTK195 can only be done by service center with RCA Chipper Check computer interface box. Sounds like possibly missing -15 volt or +15 volt supply to digital convergence circuit, bad i.c.'s U19503 or U19504. Supply voltages come from regulator supply transformer T19701 diodes CR19707 (-15 volts) and CR19709 (+15 volt)
Dec 22, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
