Televison & Video Logo
T
Taylor Hampson Posted on Aug 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba 50L1350U Tv no picture
Using a flashlight, I can barely make out what is on the screen. The audio works well. Model: Toshiba 50L1350U LED tv Through some other online sources, I think that either the LED driver board or the LED light strips are the problem. I cannot find the LED driver board anywhere on the back, so I was wondering if anyone knows how I can confirm that the LED driver board is built into the power supply board; I just need to know if there is a seperate LED driver board or not. Also, would I be better off replacing the LED strips or just the entire power board for my situation?
matt
Level 3:
  • Toshiba Master 1,666 Answers
  • Posted on Aug 12, 2018
matt
Toshiba Master
Level 3:
Answers
1666
Questions
Helped
695432
Points
9998
Mine had x6 swollen capisitors ,i replaced all 6..got off ebay,,and it works fine now,check them all first
Testimonial: "Would I find these capacitors on the main board, power board or tecon board?"
5 Related Answers
gopakumarg43
  • 76851 Answers
  • Posted on Feb 05, 2015
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Terry Corrow
johnny rebel
  • 10875 Answers
  • Posted on Mar 26, 2015
SOURCE: I have audio but. No video on my vizio model e47oiao I've seen where there is a led board but my tv only has power supply board and main board using a.flashlight I can see the menu board any ideas
if you dont have any clue,take it to someone that does or damage your tv
gopakumarg43
  • 76851 Answers
  • Posted on Dec 07, 2015
SOURCE: how do i fix a sound, but no picture led tv?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
gopakumarg43
  • 76851 Answers
  • Posted on Aug 08, 2016
SOURCE: How do I fix my Toshiba LCD TV that no picture or audio?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Testimonial: "Your link have no past posts for this model. I do my own servicing since 1966, and worked with RCA radios and TVs with vacuum tubes, so all I need was a guide to confirm that the main board could be bad. BTW, how can I test the backlights? They have two signals "Dimmer" and "Inverter" which are always at zero volts. Which one will turn the backlight inverter on?"
Larry
  • 5042 Answers
  • Posted on Mar 11, 2018
SOURCE:
Going to need more information to help much, what do the various power board rails look like?...are they all good?
Going by the fact this set has had a lot of main board failures I'd lean towards that board but its just a guess without knowing some voltage measurements
1helpful
Will the LED backlights glow even when one LED is not working?when i switch ON tv,the toshiba logo displayed for a second and then it goes off.Flash light test on black screen shows images though.
I don't know your TV but are you sure that it is an "LED" TV? If not, it may be an "LCD" TV which is a bit different. An "LED" TV uses Light Emitting Diodes to illuminate the individual pixels or PIcture ELementS. If it is an "LCD" TV, the picture works more like an electronic digital watch. The picture is produced within the screen and uses a florescent tube on the bottom and side to back light the screen. If you can see the picture with a flashlight, I suspect that it is an "LCD" type. If it was an "LED" TV, and it didn't light up, the LED's that make up the pixels wouldn't be firing and you wouldn't be seeing a picture even with a flashlight. Just like any florescent light tube, these "LCD" back light tubes will dim with age until they eventually fail. If the Toshiba logo lights and goes out, this sounds like the bulbs or their high voltage drivers are failing. Good luck.
Hi Mr Fixya, I have a Toshiba 50L1350U TV with a black screen. Yes I can see an image when I shine a flashlight on it, yes there is sound. What parts do you recommend?
Could be a bad power board or the LED's in the panel are bad...test the voltages on the power board that go to the lamps and see if its ok
NO BACK LIGHT AND NO AUDIO ON TOSHIBA Model 50L2300U but can see and image when I take a flashlight to the screen
With both the backlight and audio not working. I suspect it's the power supply board.
You'll have to get a TV repair company. Get an estimate before bringing it in, and check reviews on the company.
If you don't know Electronics, don't open it up yourself! There are hazardous voltages even in flat screen TV's!
1helpful
How to do flash light test on Toshiba model 50l1350u?
Disconnect everything from the tv.
Turn on the tv in a darkened room, turn on the flashlight and inspect the screen closely with the flashlight for any snow or text from the menu screen. If you see anything, your T-Con board and Main Board are ok.
How do you change a backlight inverter board on a Toshiba 46L5200U TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
