Question about Elgin Watches
My numbers disappeared on my clock after a power loss . He can I get them back? (I fixed my own problem, I installed a new battery, the numbers came back.)
Elgin 3455E clock
Posted by Charles Greene on
2 Related Answers
Anonymous
  • 33 Answers
SOURCE: i have an elgin rooster cuckoo clock with serial
Go to google and put in all the information you have. Some times try different ways to ask the question.. Hope this helps..
Posted on Feb 27, 2010
Anonymous
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Posted on Oct 11, 2010
I just got a Bradford Exchange Purr-fect Moments Kitten Cuckoo Clock and the battery powered clock movement doesn't work. I need to get a new clock movement with the wire that connects it to the bird
Bradford is a high end retailer. You can contact them because if the item is not over a year old then it is warrantied. The other thing is you can email them to see about the clock works inside the unit. See this page and look for "contact us" at the bottom.
Jan 05, 2015 | Watches
How do I change the battery on fossil motorcycle clock?
You will need a very small (watch or glasses) Philips head screwdriver, and a SR626SW (or know as a 377) watch battery.
Remove screw 1 to remove the motorcycle back cover.
Remove the other 2 screws to take off the clock backing.
Remove the white plastic ring by pulling directly up.
Remove the battery.
Put the new battery in.
Press the white plastic ring back on.
Reassemble the clock backing with the two screws.
Reassemble the back of the motorcycle with screw 1.
May 24, 2012 | Watches
Need to add links to a new Elgin watch band. The number on back of watch is SR626sw
That's the battery number for the watch also known as the #377. It's the most common watch battery in the world. Your model number is located at the bottom of the dial (face) below the six-o'clock position. You will need a 10 power jeweler's loupe or magnifying glass to see it and read it. Jot down the number and contact Elgin directly (MZ Berger Co,) for the extra links.
MZ Berger.
Jun 20, 2011 | Watches
I have a Sunbeam Westminster Quartz mantle clock I bought approx 17 yrs ago and after replacing the battery and setting the time again the clock stops after an hour or two. Any ideas of what the problem...
mcdevito75 here, Even a so-called new battery doesn"t really mean it"s NEW!! NEW!! in other words your NEW! battery could have been laying in a store for months before you bought it. Thes ebatteries have a shelf life of a few months, about 1 year with use in a clock / watch.---- Try another battery, also the quartz mechanism could be starting to wear., also double check the battery is installed correctly.
Jun 23, 2010 | Watches
I have a Westclox battery operated wall clock with chicken on face. The battery is new. The second hand tries to move but just "clicks" How can I fix this?
Sounds like it is just worn out.
Sometimes you can replace the generic clock works in these type of clocks. Go online and do a search for battery powered clock works, and see if you can match yours. They are removed quite easily after popping off the clock hands, and removing a nut under the hands that holds the clock works in the chicken.
Here's a link to a site that sells the clock movements... http://www.clockworks.com/
Jun 09, 2010 | Watches
HOPE THIS HELPS.
Sep 23, 2009 | Elgin Watches
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 | Watches
Repair of battery-operated wall clock
We had the same problem with our wall clock, but it was due to corrosion from a dead battery. The battery acid leaked inside and disrupted the connection between the metal contacting the batteries and the circuit (the one with the copper coil). We took everything out cleaned the contact points with acetone (nail polish remover). After that we had to bend the contact heads up just a little bit so they would contact the circuit again (I guess we bent them down a little when we were cleaning it). It worked just fine after that. I know it sounds intimidating to take apart a clock and put it back together but you're going to throw it out anyway. Just give it a try. It was kinda fun. Think of it as a puzzle. If you can't fix it, I imagine you can get a new motor at any hobby store or Michaels.
Jun 24, 2008 | Kenneth Cole 1213 Wrist Watch
Watches Logo
50 people viewed this question
Top Elgin Watches Experts
jdthefixer
Janelle Schoonover
Janelle Schoonover
STEVE SPAM REMOVER
Are you an Elgin Watch Expert? Answer questions, earn points and help others
