Question about Whirlpool Cooktops
Whirlpool induction range wfi910h0as1 starts beeping when oven gets hot
I have a Whirlpool Induction oven/range that I think works great but my wife dislikes for one reason: When cooking something in the oven, if it gets too hot it won't allow the induction elements to operate. It beeps every three seconds to let you know of the problem. Eventually, after you turn off the oven and it cools, the beeping will stop, and operation of the cooktop resumes. What causes this and how can I fix it?
Posted by David Meyer on
1 Related Answer
Anonymous
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Posted on Dec 21, 2010
I have a Maytag MIR8890AS induction range and after 10-15 minutes of running either the cleaning cycle or the having the oven at around 400F, it will start beeping every few seconds for a long time. A
new ovens and electronics have error codes programmed in, my new stove does, you need to call an electrician and tell them the exact beeping issue and this will give them an idea on what may be wrong. In the meantime see if the manual it came with has a trouble shooting or error code page, or go to http://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10562&langId=-1&storeId=10212
Dec 16, 2014 | Maytag MIR8890AS 6.2 cu. ft. induction...
I have whirlpool induction cooktop and it does nothing. I have current and nothing. I was wondering if the fuse could be bad. The fuse is 30A/250 an couldn't find one so I tried 20A/50 not
You will definitely need the correct fuse. Get someone competent with a meter to test the circuits. Test the original fuse before going further to see if it is OK or not.
Nov 15, 2014 | Whirlpool GCI3061XB 30" Induction Cooktop...
Cook top on light stays on when switches are turned off
It sounds like either a floating neuterial or one of the switches has failed.
Mar 18, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Induction error e6
Hello it07002 - You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and/or user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
May 07, 2013 | Electrolux 36" Electric Hybrid Induction...
We have as Whirlpool FXTM6 induction oven .. (and no manual). The display stays on 'STOP' no matter what you do.. how do i get out of this?
We discovered if you press in both the oven control knob and the temperature control knob simultaneously for several seconds, the stop message goes away and the oven returns to normal.
Jan 27, 2013 | Whirlpool Cooktops
F11 reading on control panel of electrolux induction range
Go to the Electrolux website on your computer and look up the model of your range. Th owner's manual should give you what you need...download it!
Dec 25, 2012 | Electrolux EW30IF60IS | 30" Induction...
Burn fuses
Something inside is short-circuited. All components look fine thans to burned fuse. Don't try it anymore with new fuses. You need to get a repairman to check it out.
Apr 02, 2008 | Sunpentown 11 in. SR-1330 Electric Cooktop
Cooktops Logo
379 people viewed this question
Top Whirlpool Cooktops Experts
Michael Thomas
Michael Thomas
Gustavo Ortiz
Gustavo Ortiz
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
