Question about Leisure Kitchen Ranges
The back on my leisure range is burning causing the paint to peel. It's just by the vent for the back of the oven. Is this normal? My tenants say it wasn't then and it gets really hot there!
Thanks all for your comments. Am I right in assuming this is a wear and tear issue even though the oven is only 2 years old or insufficient cleaning by my tenant?
Posted by Martin on
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: peeling paint
You need to thoroughly clean it, then sand it smooth to removew all the loose paint.
Once it's squeaky clean and dry, you can apply high-temperature appliance paint, which is available in brush-on or spray-on form at big box stores like Wal-Mart, home improvement centers like Lowe's and appliance parts stores.
Posted on Nov 05, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing, which can be messy.
Posted on Nov 23, 2008
Anonymous
  • 8 Answers
SOURCE: sub zero paint peeling
I have found no fix for this. I have tried repainting but it is not long before the paint is falling off again. Get ahold of sub-zero and tell them of the problem.
Posted on Jan 23, 2009
Anonymous
  • 4 Answers
SOURCE: PEELING PAINT INSIDE MICROWAVE/TOASTER OVEN
I do have the same problem, but I know they make microwave paint if you can get it from an appliance store or you can order through the web - BUT 2 sites I just looked at said a gloss enamel paint, such as that used to paint "model" toys works just as well. In either case: Smooth the old stuff off, sand lightly (you want no metal dust left -or- damaging any coating on the metal) just sand enough to make sure there's no flakes & it's smooth, then use a gloss enamel paint rather it's approved for microwaves or the Testor's kind.
NEXT -Make sure you DRY with Hairdryer to set the paint, and keep the heat to med or low, don't bubble or scorch your work!) and do not use the microwave for 24 hours!! Leave the door open while drying for several days afterwards if you can. Any fume smells can be absorbed by using -used- coffee grounds and leaving overnight. Google groups was one source the other was a repair listing forum.
Posted on Apr 03, 2009
Anonymous
  • 276 Answers
SOURCE: The paint in the cavity of my 6 year old microwave
Sand off the loose paint and make sure that there are no holes in the cavity. If there's holes the unit is not safe to use.
If it's just surface flaking, it should be safe to sand back with fine grade wet/dry sandpaper. We usually respray with automotive paint in a colour close to the cavity colour.
Posted on May 27, 2010
Testimonial: "thanks!"
My "W" key doesnt respond most of the time and when it does it types it about 12 times.
If you have already taken the key off and cleaned under it then it will just general wear and tear, if still under warranty get it replaced if not then purchase another keyboard and replace it. Then your issue should be solved.
Mar 23, 2012 | Computers & Internet
Hi, we have small budget and came across this ad, we are not sure if its worth of buying, what is your opinion, do you think it is decent buy, or to wait for a better product? Thank you in advance for your...
In my experience a display model has usually had thousands of peoples hands on it, and therefore has the wear and tear of a 10 year old appliance in a matter of days. Even if it hasn't been turned on, I would bet it has significant wear. My recommendation is look elsewhere.
Mar 09, 2011 | Microwave Ovens
The grill is 6-7 years old.. The flames are orange and leaving sud on the food..
sound like this is insufficient air in the flame...
if you can, lift burners out, spray them with oven cleaner and leave for several minutes, use wire brush and clean them under the water. pat them dry with paper, check if all holes are free of rust, fat and debris, clean as required. this should restore your grill burners to nearly new condition, return airflow back to normal and restore your flame to blue.
wear faceshield/googles to protect your eyes and gloves to protect your hands while you do that! and better you do not wear your sunday best either... oven cleaner is strongly caustic and can burn holes in the fabric and bleach it.
if you find this advice helpful, please do not hesitate to leave comment and give me your vote4, thanx!
Jul 28, 2010 | Weber Summit Gold B (NG)
Our grill consistently produces a lot of black smoke even though we are diligent about cleaning it. Our grill is 5 years old and we have never had this experience with Webers. There is another Weber in the...
The air valves are not set correctly_ I would have to assume that it was not put together "right" when it was built at the store you bought it from ( sometimes things are assembled by young kids or on a Friday)
Call Weber Customer Service and they can walk you through adjusting your air flow
Feb 21, 2010 | Weber Genesis Silver B Grill
Same thing happened to me
Toyota vehicles, that are under the 3 year/36,000 mile window, have the visors covered under wattanty. They are NOT 'wear and tear' items. Brakes and clutches are 'wear and tear' items. 3
Don't let you dealer tell you lies.
Aug 28, 2009 | 2007 Toyota Camry
I have a GE self-cleaning radiant range about 13 years old. The self-cleaning feature doesn't work anymore. The latch doorlight, even though set correctly to the right,keeps flashing on and off and the...
It could be a micro switch in the latch mechanism not communicating properly with the display circuit board, or it could be the circuit board itself. The switch might cost 20 or 30 dollars, but the board could be hundreds. Kinda costly if you ask me...
Mar 13, 2009 | GE Kitchen Ranges
2000 CR-V: Advice on recommended repairs
If your fuel filter is in the tank $149 is reasonable, and beings its almost 10 years old it would be good to change it. The suspension bushings are probably due to be changed even though you have low miles the climate and everything wears them over time so it is possible. I would say if you have the money go for it, but its not like you need to rush out and have these repairs done right away.
Feb 21, 2009 | 2000 Honda CR-V
Camera shutter issues
Dege,
You were hearing extra clicking or noise on long exposures right? I thought it was a dirty shutter so cleaning is what I thought should help. If your shop thinks it needs a repair that is a bit more pricey than thorough cleaning. If you suggest to them to consider cleaning the shutter mechanism so the parts move smoothly instead of repair / replacing how much less would that cost? Also would they think that would be enough, they may have seen some corrosion or misalignment that is snagging or hanging the shutter up, so it may need the extreme solution. If they don't recommend it or are insulted by your desire to think about another solution seek a second opinion, there's nothing wrong with trying to save some money esp. if you don't need that type of surgery, you know what I mean. If the other shop says yes that shutter is damaged and needs it. You know you have to do it eventually. Just find the best price wiht the shop that you like. As far as the normal wear & tear not really, we are shooting a D80 purchased in Dec 2006 at an average of 1,000 shots a month sometimes more. My wife is a photographer as has really used it constantly, it has been very reliable. Since your camera is more than 2 years old it is out of warranty. I will check Nikon for any sort of recall or issue with the shutter and get back to you.
randy320sgi
Jan 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Kitchen Ranges Logo
52 people viewed this question
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
Chuck Graybill
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
