You are asking too much of an air conditioner. Its air conditioning not refrigeration.
AC control thermostats main programming may have the low cooling setting programmed that way and may need reprogramming to your use needs.
The thermostat also, when programming and setting, the heat setting would need to be set to the lowest minimum setting value. Example: heating minimum setting is set for a minimum of 65*, the cooling cannot be set lower than the heating, include 2-3* margin between the two main settings for cooling and heating settings ranges.
Bottom line: set the heat setting to fifty, then set your cool setting.
SOURCE: 2002 Outback air condistioning
It's probably the revolution sensor. see http://endwrench.com/images/pdfs/Service07MayEW.pdf
SOURCE: AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
SOURCE: ford ka heater blows hot air all the time
Your problem is a faulty heater control valve. The design used on these vehicles allows for hot water to flow constantly and compete with the evaporator as there is no blender door. You have to replace the valve and possibly the control head. Meanwhile, you can bypass the valve to have cold air
