Question about Polaroid Televison & Video
How to program a Polaroid digital TV without a remote
Posted by Amanda Lyman on
    Top Expert:
  • Polaroid Master
  • 76,365 Answers
Without a remote control, you can't. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}
Posted on Aug 11, 2018
5 Related Answers
Anonymous
SOURCE: DirecTV Remote Control of Polaroid TLA-01511C
These worked for me
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341, 11498, 11523, 11991, 11992
Posted on Dec 10, 2007
Anonymous
SOURCE: remote control code
i have a universal remote gemini G610S polaroid tv model TLU-OO1541CU, does anyone know the codes for the remote.
Posted on Jun 25, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Polaroid TDA-03211C Combination 32 inch, LCD-TV/DVD *1080i/720p*
Check required Codes for TV Here for DishNetwork remote.
Posted on Oct 03, 2008
Anonymous
SOURCE: POLAROID FLM-2011 REMOTE CODES
My cox remote guide lists for the Polaroid TVs the following codes:
LCD TVs: 1276 and 1316
TVs: 0765, 0865, 1276, 1314, 1316, 1326, 1327, 1328, 1991, and 1992
I hope one of them works.
Posted on Oct 12, 2008
gcrcomputers
David Fitch
  • 170 Answers
SOURCE: I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
Posted on Mar 17, 2009
I have a univesral remote and I'm trying to turn on a Polaroid flm tv
You need to program your universal remote to one of the 3-digit TV codes listed for a Polaroid TV
015
024
031
046
086
092
097
224
228
006
110
026
118
119
Feb 24, 2017 | Polaroid Televison & Video
Where can I buy a remote control for my polaroid tv
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
Mar 22, 2014 | Polaroid TLA-01911C TV
HAVE AN ALL IN ONE REMOTE BUT I LOST THE CODE
Hello Susan,
I can usually find remote codes for most brands of replacement remotes by simply using GOOGLE. Find the brand and model of your remote control, not the tv. Enter the model of the remote on google and add the word remote codes. you should find a user manual online for your remote control. Then program as necessary for your Polaroid TV.
Mar 13, 2014 | Polaroid TDA-03211C 32 in. LCD HDTV
I have removed all cable boxes from my home. I cannot get the tv remote to change channels. I was told by the cable tech that I needed to do a channel search. How do I do that?
Which specific model do you have? The menus may depend on your model. Are you using the original TV remote or a different remote? If you do not have the TV remote, try the buttons on the TV. Use the channel up/down buttons to navigate through the menu items and the volume up button to enter a sub-menu.
Try Menu and locate the Channel sub-menu. Then make sure that the antenna Air/Cable item is set correctly. Then the Channel Search option is on the next line. This is the method for the LCD2050. For the TTM2901L, you need the same Channel sub-menu but the channel search is called "Auto Program".
A number of other manuals for Polaroid TVs are available here: http://www.polaroid-tv.com/polaroid-lcd-tv/manual/ .
I hope this helps. If you add a comment with your model number, I'll be glad to provide additional help. (Note: without the model, I can't be sure which tuners (NTSC - analog OTA or cable, ATSC - digital OTA, or QAM - digital cable) are in your TV. This may change whether you can receive any stations without the cable boxes.)
Jan 25, 2012 | Polaroid Televison & Video
I have an rca universal remote control to program my polaroid tv, what the code for the polaroid tv
Hello
Four digit universal remote setup codes for Poloroid TV are: 0182 / 0173 & 0133. OK.
Oct 06, 2011 | Televison & Video
Can't find Polaroid TV Remote Control Programming
Tries this website.1-800-Remotes Factory Original.Get the original remote or very close to the original.
Sep 11, 2009 | Polaroid FXM-3211C 32 in. LCD TV
I hope this helps,
David
Mar 17, 2009 | Televison & Video
Program remote to a direct tv reciever
You are most likely out of luck using these as universal remotes. You are better off purchasing a Logitech remote and programing it for the Polaroid and your Directv box.
Jan 06, 2009 | Polaroid FLM-3232 Television
Polaroid TLX-04244B Remote wont work
5 Digit code is 15231
3 Digit code is 494
Hope that helps, took me about 4 hours to get that figured out!
Nov 28, 2008 | Polaroid FLM-4201 42 in. LCD Television
I am trying to program fios set top box remote control and need the code for my Polaroid TV.
I own a One-for-All universal remote, and my booklet says the setup code for a Polaroid TV ( without a built-in VCR or DVD) is 0765. I can not be sure, if this number will work with your remote, but it is worth a try.
Jul 02, 2008 | Televison & Video
Televison & Video Logo
88 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
