Question about Humminbird Boating
I have a humminbird 997c that flickers barely when trying to power up. I have 13 volts to the back of unit. Any ideas on what problem could be.
Posted by Brian Yawn on
Andrew Taylor
    Top Expert:
  • Humminbird Master
  • 33,322 Answers
2 Related Answers
Anonymous
  • 148 Answers
SOURCE: Searching for Satellite
The voltage is supplied by the power-supply through the RF/IF interface usually encased in a metal box on its own. Also without knowing the model number of your unit I cant help any further.
Posted on May 17, 2008
Anonymous
  • 67 Answers
SOURCE: MacBook 13" starts but screen is barely visible.....
could be your inverter board, whitch controls the backlight. I could very well be the backlight as well, but that is less likely. Inverter boards are not all too expensive, and if you are knoledgable with laptops, i would say doit yourself, but if you have any doubts, take it to apple, sur it will cost more, but it is the safet bet.
Posted on Jan 18, 2010
How to get a brighter contrast on a humminbird 898
its your back lighting try pushing your power button after unit starts up 3 times real quick see if that brings back lighting up some units have 3 light settings
Nov 10, 2013 | Humminbird 898C
It shut off and will not come back on. Its less than a year old, and only used four times.
I would check my connections on my power source and make sure I have 12 volts. If you have 12 volts on your power cable then I would contact our customer service group. They will glad to help you out. Our number is 800-633-1468.
Joby @ Humminbird
Jan 03, 2011 | Humminbird Sport & Outdoor - Others
My 997c has a low voltage message on the screen every 20 minutes.
When you have a low volt warning, it is simply because you have low volt. To confirm this use a multi-meter and check the voltage at:
A- the power connector for the GPS
B- the battery directly.
If A is bellow 10.5 V and B is above 11,x you have a cable problem (long or/and thin cable). If they are more or less the same, but bellow 10.5V you need to check your electric system.
Oct 23, 2009 | Humminbird 595c GPS Receiver
Hi guys, i bought one a year ago, and just got it
Hi!
If your 220 is in portable configuration (runs on 8 'AA' batteries) make sure that the batteries are 1.5 volts and not 1.2 or 1.3 volts. (1.2V times 8 batteries is only 9.6V)
Also check the battery compartment as we see leakage from some batteries which corrodes the connector plates that the batteries hook up to.
One more thing...check to see that the power cord is plugged into the unit with the notch in the plug pointing UP. The rubber plug housing on the sounder allows the cord to be plugged in backwards if it's forced a litlle bit.
Best of luck!
Mike
Sep 26, 2009 | Humminbird Piranhamax 220 Fishfinder
Humminbird 343c will power down on its own
Hi!
If the unit shuts off on its own, firstly check your power supply. I keep seeing customers running their ssounders from a small, portable battery configuration that doesn't put out the correct voltage...mostly seen with AA size batteries being rated at 1.2 or 1.3 volts (8 batteries times 1.2 volts is only 9.6 volts).
If the power supply is not the issue then I would say the internal power circuit is suspect...this can only be repaired by a competent repair person who knows how and what they are doing. If you open the unit up, you'll not only void the warranty, you run the risk of killing the entire unit from static shock.
Best of luck in your repair!
Mike
Aug 24, 2009 | Humminbird 343c Fishfinder GPS Receiver
My Humminbird Matrix 67 shows 11.3 volts on the
Hi!
Go into the menu (press menu twice) and look for the alarms tab. There is a setting you can change for a low battery warning, make sure it is set to off or as low as you can get it. Also it may be time for a software upgrade (available at a service center)
Best of luck!
Mike
Jul 08, 2009 | Humminbird MATRIX 97 GPS Receiver
Humminbird 240 won't start
Hi!
If your unit is a portable unit (takes 8 'AA' batteries), make sure that the batteries say 1.5 volts and not 1.2 or 1.3 volts as these won't have the right amount of power.
If not, make sure that the power cable (where it plugs into the sounder) is installed with the small notch pointed towards the top.
Best of luck!
Mike
Jun 09, 2009 | Humminbird 595c GPS Receiver
Stuck on loading page
Hi!
I suspect that the software is corrupt in your unit.
Being a newer model, if it's still under warranty, contact humminbird or one of their service centers for repair:
Authorized Service Centers - Canada Bay Distributors
119 Progress Ct.
P O Box 70
North Bay, Ontario, Canada P1B 8G8
Tel: (705) 476-6010
Email: [email protected]
Mike's Reel Repair
#108-31060 Peardonville Rd
Abbotsford, BC V2T 6K5
Tel: (604)855-1119
www.mikesreelrepair.com
PTG Electronics Ltd.
3092 Portage Ave
Winnipeg, MB R3K 0Y2
Tel: (204)831-0862
Fax: (204-888-6207
Where to ship your items:
(if you live in the U.S.)
Humminbird
Attn: Service Dept.
678 Humminbird Lane
Eufaula, AL 36027
Who to call:
Toll-free: 1-800-633-1468
Monday - Friday
8:00am - 4:30pm CST
Apr 11, 2009 | Humminbird 997C SI COMBO W/TM GPS SENSOR,...
Need a manual
Humminbird - Support Your product is listed. However, when you click to download the manual, the page is not available. Fill in the question, for support.
Feb 16, 2009 | Humminbird Smartcast Rf 35 Dual Display...
Boating Logo
163 people viewed this question
Top Humminbird Boating Experts
Mike
ray gallant
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
