Question about Nakamichi Televison & Video
I have a Nakamichi TV NS4700LE. It gets switch off and switch on automatically. Also the TV Remote is not sensing. Pls help.
Posted by Manoj on
1helpful
Nakamichi nk12 remote code
Scot, Nk12 universal remote code, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Infrared Hex Code Database Nakamichi Model List
Shockwafe
http://www.hifi-remote.com/devices-amp.shtml
http://remote-codes.findthedata.com/l/216/Nakamichi-Remote-Codes
1helpful
I changed the batts stopped working, done quick scan, tried codes, i can get it to turn the tv on and off, , but i need to be able to use the menu and av so i can change tv onto hdmi
First off, you can change into HDMI without the remote, there is an input button on every tv near the power button. Secondly if the remote came with the tv you shouldn't need to program it. If it did not come with the tv then you do have to program it, and codes should be easily found online at the remote brands website. Lastly, if you can turn the tv on and off with the remote, you should be able to use the other keys as well, maybe you need to hit the tv button on the remote or something, it doesn't make sense that the power button would work but not the others...
Need code to use Nakamichi NK5 with Direct TV remote
use your manual,it would cost money to find out for you,i have answered 3 of your questions.
2answers
Why does my t.V keep switching to dvd screen.
TVs turn on in the last screen they were turned off. Try switching screens using the remote control. If the dvd screen keeps coming back, try pressing or tapping on the manual key located on the side or bottom or back of the TV panel. Sometimes this key gets stuck up. If this does not work, try unplugging your home theater and turn on the TV. Most TVs automatically switch to DVD when they sense signal from HDMI cables.
1helpful
When i start my tv automatically turn-off like we turn-off by remote control.
Just close the infrared sensor window at it front panel with any opeque material, like a diary or so. Then try to switch it ON. If the set behave so, even after blocking the infrared sensor, make sure that there is something fault with the main system control section. Need a through checkup. If it switches ON without any problem now, make sure that there is no energy saving lights; like CFL or so, in front of the TV.
Nakamichi tv
My smart tv nakamichi, while swith on only shows android and busy, even remote not functioning. . Pls advice
34helpful
4answers
How to switch off psm in bpl tv?
first you can take og remote controll,then press and hold power key.this time tv will going off.bt dont relealese power botton of remot...after turn on tv...........tv will psm off.......
dkm kerala
+919447259335
Televison & Video Logo
Top Nakamichi Televison & Video Experts
ray gallant
Tom Chichester
Are you a Nakamichi Televison and Video Expert? Answer questions, earn points and help others
