Question about Musso Stainless Steel Pola Ice Cream Maker
Dak gelatisimo machine broken gears
Machine dates from late 80's wont churn gears seem to be broken from ice cream getting to hard. is it worth or possible to repair?
Posted by gelatissimo on
  • Anonymous Jun 10, 2008
    The belt is broken and I cannot find one. Anyone know where one might be available. It is a 120-XL DAK Gelatissimo Ice Cream Maker
Anonymous
    Problem Solver:
  • 12 Answers
I just helped a problem similar. It is possible to get a repair man and fix it. Get a hold of a repairman at www.repairman.org. I do not know the number but i'm shore it is on that website.
Posted on Dec 08, 2007
denunfried
  • 3 Answers
The following Gates belt will work. Its called Poly power chain belt which is metric and just under 12 inches with 60 teeth. Just Google the number and you will find several suppliers online. Costs around $24 which is cheap to fix such a great machine.
Product # 5MGT-300-09
Posted on Mar 06, 2010
How long do I churn mixture?
Probably 15-20 minutes depends on machine and mixture. Some machines stop churning when the ice cream gets so thick that it stops the beater from turning. If you have this type of machine, when you hear clicks turn it off. If you start with a frozen container vessel, your ice cream will freeze faster. Remember that longer is not necessarily better. The longer it is out, the warmer it gets, and will turn back into slush.
Aug 28, 2016 | Ice Cream Makers
Discovery kids ice cream maker instructions
Usually with these cheaper ice cream makers you put the bowl in the freezer for 12 hours and then put it on the machine and turn it on . Very important point turn it on so it is churning. Why so that what ever you pour in doesn't freeze solid and stop the agitator from churning. Most ice cream is Cream and sweeten condensed milk and flavouring. I do not have this exact ice cream maker but the one I do have has made three different ice creams in it so far. Add 1000 mL of cream to 250 mL sweeten condensed cream. Watch it for about 20 minutes till ice cream is solidifying then transfer to an plastic icecream container and put in freezer for at least 4 hours.
Aug 19, 2015 | Ice Cream Makers
Gaggia ice cream machine
Ice cream won't churn but the freezer it's on
Nov 24, 2013 | Gaggia Ri9101/08 Gelatiera Ice Cream Maker
I have an old Simac Il Gelataio Super. I believe the clutch is broken. It will only churn until the product is very soft. Then the blade stps because the drag on the sides is too great. Is this...
It sounds like the main gear is cracked were the paddle shaft goes though it.the d shaped shaft is spinning when the ice cream gets firm. i repaired mine by making a sleeve out of copper pipe and slid it over the cracked part. works great.
Dec 11, 2010 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
My ice cream churn just spins the lid and does not turn the canister. The only thing that is different is that the lid does not seem to come to a halt when I place it on the cannister and turn it. There...
maybe you have a super strong husband who tried a little too hard to loosen the lid once and now it won't seal or catch. if he is equally smart as strong maybe he could get some sort of gasket type idea going with the lid or something else ingenious. but it sounds like that might not be up his ally as much as throwing it across the room. could you try buying a new lid since everything else is working well? maybe the lord is telling you to get more iron in your diet and less ice cream? ha!
julie j your beloved daughter
Aug 18, 2010 | Rival F69206 6 Quart Ice Cream Maker
Just receive this machine and am not sure which switch is the chill land which switch is the churn!
Simple. The churn button is the one with the swirl on it (i.e. indicating churn). The chill button just looks like a snowflake.
Jun 25, 2010 | Musso Lussino Dessert Maker 4080 1.5 Quart...
Homemade Ice Cream Inconsistency
It is possible, but the rivals don't have much power. In an hour it should be frozen anyway. I have an 8550X5 and it never got very firm. Now the gears are stripped. Typical for Rival.
May 10, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
I have the DAK Gellatissimo machine with Broken Belt as well
Oct 03, 2009 | Musso Stainless Steel Pola Ice Cream Maker
Instruction manual
Can I have the make and model of the ice cream maker please?
May 07, 2008 | Back to Basics ICM32 10-MInute Ice Cream...
Musso Stainless Steel Pola Ice Cream Maker Logo
472 people viewed this question
Top Musso Ice Cream Makers Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Musso Ice Cream Maker Expert? Answer questions, earn points and help others
