Question about Advance Audio Players & Recorders
Hae am from Africa Kenya..my BOSS ME 25 does not produce any sound ..everything else is working only the signal to hear what you are playing... Thanks in advance for your help.. Chris k.
Posted by chris kuria on
5 Related Answers
Anonymous
  • 631 Answers
SOURCE: boss chaos 150 200 watt that shows light but doesn't produce sound
If this is the CH150, it's not bridgeable. Try connecting it normally (one speaker per channel) to see if it will produce output.
Posted on Dec 05, 2007
Anonymous
  • 440 Answers
SOURCE: dolby digital signal
yes go in main menu of tv audio output and use dobly digital out ok not pcm anlog ok
Posted on Feb 03, 2008
Anonymous
  • 76 Answers
SOURCE: Notation Technologies Play Music 1.0 No sound when playing back song.
hi this Probalm is your sound Drivers check your sound drivers
Posted on Mar 19, 2008
Jaime Hernandez
  • 2351 Answers
SOURCE: no sound from speakers
It looks like the audio amplifier could be defective.
I would suggest to get a technician since this devices are not very easy to disassemble to replace the IC.
Posted on Apr 10, 2008
Anonymous
  • 1913 Answers
SOURCE: no signal check input cable .
when u start the pc press F8 key then go to enable vga mode or safe mode or last known good config...
then set your display resoluiton to 800*600 or 1024*768
thatas all.
Posted on Oct 09, 2008
Where do zebras live
Though they all live in Africa, each species of zebra has its own home area. Plains zebras live in the treeless grasslands and woodlands of eastern and southern Africa. The Grevy's zebra lives in in the arid grasslands of Ethiopia and northern Kenya. The mountain zebra is found in South Africa, Namibia and Angola.
Speaker output doesnt work
Hi when using surround sound its important to understand that not all soundtracks have a "rear channel' meaning that the rear speakers will not always produce sound. In fact the rear channels may only produce sound about 10% of the time.
Your receiver has a "test tone" which sends a tone sound through the 5 speakers you should turn the speakers up or down so that all 5 speakers produce about the same volume.
The speakers of course will have a different sound to them depending on the brand and model but just try to balance it as much as possible.
Should also point out that you need to start out with at minimum a STEREO signal and that it needs to be connected with good quality cables. If possible use the optical inputs or HDMI which is a digital signal but not all receivers have that capability.
Lastly play around with the settings Dolby is of course the standard but many receivers have Neo or other proprietary surround formats which may produce the desired effect.
Hope that helps
Jan 02, 2010 • JVC RX-558V
There is a constant loud hum/buzz whenever I turn the pedal on. With my Boss Mt 2 Metal Zone effects pedal. It happens whether or not the power supply is plugged in. Ive tried switching cables and...
First and foremost , check your signal chain. By that, i mean put the pedal aside, ...just unhook it and take it out of your signal path. Using the same cables , guitar , amp, other pedals - borrow a friends MT-2 if you can get one , and try THAT to see if THAT works , OR any other kind of distortion pedal. If another one works ok , it's YOUR MT-2. Boss pedals are pretty rugged , but sometimes the little actuator (on/off switch) underneath the treadle (where you push your foot down) will become faulty. That's a high-gain pedal - are you using a basic Strat or other single-coil pickup guitar? If so , are you playing close to any flourescent lights? SIngle coils are noisy around those lights. Will cause a hum / buzz if using a heavy dist. pedal. You can check that by moving around as you play.
The BOSS FDR-1 produces a popping sound when played
This is a common problem with this pedal experienced by allot of people. My best advice would be to sell it and put the money toward a real Fender tube amp and some good pickups. If you're trying to go cheap check out some Line 6 modeling stuff.
Oct 08, 2009 • Boss Music
1helpful
Boss chaos 150 200 watt that shows light but doesn't produce sound
DID YOU CONNECT THE JACKS FROM THE HEAD UNIT? JUST A THOUGHT AS THIS IS EASY TO OVER LOOK
2answers
2answers
Gxm 30
Me too same problem, no audio with the XM. Do you think it has anything to do with Audio-Video out setting on the unit?
No Real Time Sound from USB Port in Headphones
The problem is due to the design of the DELL Laptop itself. It is not dsigned to monitor the incoming signal. I bought a cheap Behringer UCA202 USB-Audio Interface. It provides for real time monitoring the incoming sound. I can also hear the accompanying music while I play along with pre-existing tracks. It's not the highest quality but it was only 25$ so well worth the price.
No image, Hear sound, Flashing light
Look for over-heated area on PCB===change 47mf/25v cap and two xistors== BC-327-25=BC-328 BC-337-25=BC-338 This solution is offered for L04-01 chassis.
Top Advance Audio Players & Recorders Experts
Ginny Larson
ADMIN Andrew
ADMIN Andrew
ray gallant
Are you an Advance Audio Player and Recorder Expert? Answer questions, earn points and help others
