Question about Furniture
2720318 wine enthusiast cooler my son gave me. my thermostat reads 46 deg in lower unit LED display reads 77-81 where to by and how to repl lower therm can I buy lower therm and install myself, if so, how ????
Posted by bob higgins on
  • bob higgins
    bob higgins Aug 10, 2018
    Called wine enthusiast tech-support they are mailing me a $9.95 temperature sensor I’m gonna try to replace it myself
    their tech thinks that’s a problem
5 Related Answers
Sheldon Dedek
  • 912 Answers
SOURCE: Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Posted on Nov 02, 2009
Anonymous
  • 534 Answers
SOURCE: Wine cooler FWC20T is not working , purchased 4/2009
Mike, what I would do is get a stick of dynamite( not really) Go to an appliance parts house with the model and serial # of the unit. You may still be able to purchase the board in question from them. If they can't help you I would find a store that sells wine coolers and ask them. Unless the company you bought this cooler from had a patent on the circuit board then they are mostly generic. You may have to wire the board up a little different but the new board's information paperwork will tell you the wiring diagram for the unit.
Good luck hope this helped you in some way
Dave
Posted on Jan 29, 2010
Anonymous
  • 86 Answers
SOURCE: I have a "the wine enthusiast" wine cooler and
At that temp I'm sorry to say sounds like the compressor is shot or all the gas has leaked out. A service call is about $100.00 to ring the door bell and then add about $500.00-600.00 for a compressor and or 300.00 if the coil is bad. It might be better to get a new box with a warranty. Best of luck!
Posted on Aug 23, 2010
David Ellis Rhea
  • 3462 Answers
SOURCE: I have a Wine Enthusiast 18 bottle refrigerator Model 2720318. The unit is not getting any power. I have power to the wall plug and the unit is plugged in. Any suggestions on this problem ?
Well, in a word, yes.
Look underneath the refrigerator and see if you can see the compressor anywhere, it may be covered up and you may need to remove a cover to see it.
. If you cannot, you may stop reading here.
If you find it, you should also see a small electrical switching unit mounted on it.
This unit may be the size of your fist.
It should be made of two (2) pieces, one of which is a "Klix-on". The Klix-on is the starter relay for the compressor.
If you find this, take a small hammer and tap on it, whilst the fridge is plugged in and on.
If the compressor starts, you will need to replace the starter relay/Klix-on.
I paid about $ 35 for it at my local appliance parts store.
God bless your efforts.
Posted on Apr 11, 2017
Bill Boyd
  • 53816 Answers
SOURCE: I have a new eurodib 46 bottle wine cooler and neither the upper or lower units are cooling to set temps.
new --under warranty , have it checked under warranty
Posted on Apr 03, 2018
Apr 11, 2017 | Wine Enthusiast Refrigerators
Tip
Benifits of Wine Coolers & Accessories
Wine Coolers are a great choice for many wine enthusiasts. Wine Coolers & Accessories can be placed virtually anywhere in the home and Wine Coolers offer either a single or dual temperature control zone. A wine accessory is generally any equipment that may be used in the storing or serving of wine.
http://www.jilliandistributors.com/products/wine/
on Aug 16, 2016 | Furniture
Vinoview #272 02 35 18 wine cooler stopped working and makes a clicking sound
sounds like you have a compressor overheating is it enough air circulation where the unit is located and check to see that the condensing coil and motor are clean too.
Dec 11, 2013 | Wine Enthusiast VinoView Silent 35 Bottle...
I need to lower the temperature
There is a thermostat that is seen on the unit , you will have to set the thermostat to a lower level. Also check if there is any gasket leak to confirm that the cooling does not stay.
Keep the cooler away from hot spots to encourage the cooling to stay.
Sep 17, 2010 | Emerson (025806803716) Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Fridge not running well
Not sure of what type of fridge you are refering to.. However you can try a few obvious things. Try turning the thermostat to a lower number (warmer setting) to see if that makes a difference. If you have an ice build up starting to form on the fridge plate or only a partially cold plate then you could have either a loss of refrigerant or compressor fault. Is the compressor noisey in comparisson to its normal noise. Is there heat being produced all over the condenser (black finned section on back of cabinet or underneath cabinet)..If not possible gas leak. Hope this is of some help.
Sep 07, 2007 | Haier BC112G Wine Cooler
Furniture Logo
624 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
