Http://printcopy.info/?l=en&mod=erc&brand=canon&model=iR2270
Quoting from link:
Canon iR2270 Error Codes List page 1 from 24
Code:
Exploded Views and Parts List Free!
While startup control is under way, the reading of the main thermistor is less than 30 deg C continuously for 200 msec or more 1 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 70 deg C continuously for 200 msec or more 2 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 120 deg C continuously for 200 msec 6 sec after the start of power supply. The startup control does not end 30 sec after the start of power supply.
SOURCE: need cd and user manual for canon Ir 2270 copier/printer
the cd is not needed goto canon and download driver for printing. as for manuals if you dont have them only an authorized tech can get the actual manuals do to canon putting them on the tech site. but you can find websites that will charge you and you can get a manual
SOURCE: IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
SOURCE: Canon IR 2270 The copier print
these means that copier cant detect the toner in developing/toner assy.
You should try to reconnect the toner developing assy and try to vacume it.
Also check if the toner bottle is rotating, if yes that means that toner is being dosed and problem is developing assy.
If you do not want to call service write me on [email protected] for service manual.
hope that helps!
Testimonial: "very helpful i just remove check and reconnect the toner cartrige and the issue is solve "
SOURCE: We have a Canon iR
if e000024-0001 is comming plz clean the toner box in which magnet roll is runing then try you machine is not give this e000024-0001 singnal.
SOURCE: The canon ppc( model. ir 2270) fonund the problem
remove the front cover and take ink out from wastage unit
